Rationalizing a denominator with fractional exponents
  • Thread starter Thread starter Nekomimi
    Exercise
11 replies · 3K views · last reply
Nekomimi
Described below.
None.
Express the following as a fraction with rational denominator: $$\frac{5^{\frac{1}{3}}}{5^{\frac{5}{3}}}$$
If I try to start by multiplicating both the numerator and denominator by ##5^{-\frac{2}{3}}##, I get:
$$\begin{align}
\nonumber \frac{5^{\frac{1}{3}}}{5^{\frac{5}{3}}} & = \frac{5^{\frac{1}{3}}}{5^{\frac{5}{3}}} \times \frac{5^{-\frac{2}{3}}}{5^{-\frac{2}{3}}} = \frac{5^{-\frac{1}{3}}}{5} \\
\end{align}$$
Which apparently makes me stuck because that negative exponent will make the radical go back to the denominator anyway, and I can't seem to get it out of there. Any help?
I may be missing the point about rationalizing denominator, but given expression is also 5^(1/3-5/3)
= 5^(-4/3)
= 1/(5^(4/3))
Rationalizing that might be easier, involving cube root of 5. Your step here may be to use (5^(1/3)*5^(1/3))/(5^(1/3)*5^(1/3))
Nekomimi said:
Problem Statement: Described below.
Relevant Equations: None.
$$\begin{align}
\end{align}$$
Here's another thought -- do some simplification first before attempting to make the denominator rational.
$$\frac{5^{1/3}}{5^{5/3}} = \frac{5^{1/3}}{5 \cdot 5^{2/3}}$$
Now multiply numerator and denominator by ##5^{1/3}## over itself.
BTW, the word is "multiplying," not multiplicating, which isn't a word in English
Right, so
$$\frac{5^{1/3}}{5 \cdot 5^{2/3}} \cdot \frac{5^{\frac{1}{3}}}{5^{\frac{1}{3}}} = \frac{5^{\frac{2}{3}}}{5 \cdot 5} = \frac{5^{\frac{2}{3}}}{25}$$
Is that right?
Mark44 said:
BTW, the word is "multiplying," not multiplicating, which isn't a word in English.
I'm sorry for the mistake, English is not my first language.
Watch carefully (also because my typesetting skill is not very good) that:
5^(1/3)*5^(1/3)*5^(1/3)=5^(1/3+1/3+1/3)=5^1=5
I don't understand where I should do that.
Was my last try incorrect?
I agree with post #3 and #4, since I just now worked the problem on paper. I did the work two different ways.
Oh, I think I get it now. Your tip was for solving it through the way I initially started with? (That is, by not simplifying ##5^{\frac{5}{3}}##.)
Well then, let's see:
$$ \frac{5^{-\frac{1}{3}}}{5} = \frac{1}{5 \cdot 5^{\frac{1}{3}}} = \frac{1}{5 \cdot 5^{\frac{1}{3}}} \cdot \frac{5^{\frac{2}{3}}}{5^{\frac{2}{3}}} = \frac{5^{\frac{2}{3}}}{25}$$
Is that right?
Not a problem -- your English is very good. I was just letting you know for future reference.
This would be much more readable in LaTeX. Here's the same work in a more readable form:
##5^{1/3}*5^{1/3}*5^{1/3}=5^{1/3+1/3+1/3}=5^1=5##
All I did was add a pair of # symbols at each end and replace each parenthesis with a brace --{ or }. Take a look at our LaTeX primer -- https://www.physicsforums.com/help/latexhelp/
Yes, that's right. My only quibble is that you should start with the first fraction of the given problem, ##\frac {5^{1/3}}{5^{5/3}}##. The step you don't show above is multiplying top and bottom by ##5^{-1/3}##.
Don't you mean multiplying by ##5^{-\frac{2}{3}}##? In any case, yes, I skipped that step because it was previously mentioned. I'll keep that in mind for the next time, though.
Since it is solved, is there a way to close this thread?
Maybe what I wrote wasn't exactly what I meant.
Probably the easiest approach is what I suggested in post #3:
##\frac{5^{1/3}}{5^{5/3}} = \frac {5^{1/3}}{5 \cdot 5^{2/3}}##
Now, multiply top and bottom by ##5^{1/3}## to get a denominator of 25.
Not that I know of. There used to be, but we've updated to a new system that doesn't have that feature, I don't believe.
OK. Thank you very much, anyway!
