Really clueless = Minimum Mass Tension Force Question
9 replies · 4K views
Pandaanli
A fisherman yanks a fish straight up out of the water with an acceleration of 2m/s^2 using very light fishing line that has a "test value" of 50 pounds. the fisherman, loses the fish as the line snaps.
What is the minimum mass of the fish?
The answer given is mass=18.9kg
No additional information is given, and it's just a question by it self, no other values attached.
I converted pounds into kg since they asked for mass as solution
They asked for 3 Sig Figs, so 50 pounds =22.72kg
I'm assuming the acceleration is 2m/s^2 all the way
but I'm not sure how that get me the 18.9 kg answer
I'm seriously clueless with this question, about both the concept and how the answer is gotten. Been trying to figure it out for at least 3 hours, really need your help Q__Q
Please and Thank you!
When a fisherman yanks a fish straight up out of the water, the acceleration of 2m/s^2 should be added to gravity acceleration (9.81m/s^2).
regards
regards
Thanks for the reply, Bartek!
I plugged the new acceleration in, and played around with different equations
I've got many answers, but none that's 18.9kg
F= ma
= (22.72)(11.8)
= 222.656 N
How should I continue next?
F= ma
= (22.72)(11.8)
= 222.656 N
No! When line was tested a=g. So Fmax is (22.72)*9.81, not 11.81 (during test the mass of 50 pounds hanging motionless). F_max is a maximum line tension.
When fisherman yanks a fish, this Fmax should be equal to (m_fish)*(2+9.81). You can calculate m_fish.
regards
ps.
50 pounds is equal to 22,6796185 kg, How did you got 22.72?
regards
ps.
Hahah I have no idea how did I get 22.72, probably 1kg = 2.2 lbs
Thank you so much ♥ Finally it's solved~! :D
BTW, I have another tensions concept question
Two tug-of-war teams are at opposite ends of rope. Newton's third law says that the force exerted by team A will equal the force that team B exerts, how can either team win the tug-of-war?
Does the player's mass and friction play a role?
Imagine both teams and a rope as a one rigid body. What forces exert this "body" horizontally? When it will be moved?
Friction force exerts on the body horizontally, it'd move when the forces on one side is greater than the other? But what's going to trigger that unbalanced force?
Yes.
muscles :biggrin:. Both teams are pushing the ground... so, ground pushing the teams. Stronger win.
Bartek said:
Yes.
Thank you thank you ♥
I can finally hand in my work and sleep in peace :D
PS, are you teaching physics? or just doing for fun?
