Really need some help on Quadratic Formula's ect
  • Thread starter Thread starter travishillier
    Quadratic
Markita needs to fence a rectangular plot of land with an area of 500m² using 100m of fencing, with one side open to a lake. To find the dimensions, the area (A = L * w) and perimeter equations (P = L + 2w) are established. By expressing length (L) in terms of width (w) and substituting into the perimeter equation, a quadratic equation is formed. Solving this quadratic will yield the dimensions of the plot to the nearest tenth of a meter. Understanding the relationship between area and perimeter is crucial for solving this problem effectively.
travishillier
Really need some help on Quadratic Formula's ect ...
Heres the question ... your help is greatly needed and appreciated ...
Markita wants to fence a rectangular plot of land along side the shore of a lake. Only 3 sides must be fenced, since the lake will form teh lake will form teh fourth side. Markita had 100m of fencing, and she wants the plot of land to have an area of 500m^2 (squared). Find teh dimensions of the plot of land, to the nearest tenth of a metre. Expalin and justify your solution.
Theres thequestion , lmk what u can do to help me out ... Thx
Mathematics news on Phys.org
Let the length of the fence be L and the width be w.
Can you find an equation relating area to L and w?
Can you find an equation relating perimeter to L and w?
Can you solve this system of equations?
cookiemonster
Hey ... i ahve absolutley no idea how to even start this question, we have a test on a question like this tomrow and thought i coem here to get teh proper format ect basically looking for teh compltete answer so if u can help me on that i woudl greatly aprreacite it.
I just told you how to start the question. If you're not willing to put in effort to attempt to solve it, then looking at the answer isn't going to help you on the test anyway.
cookiemonster
furhtermore... Whats the maximum area that this fence can enclose? :P give it some thought.
What are the formulas for area and perimeter of a rectangle ? Use the area formula to write the length(L) in terms of the breadth(W). So now, your length and breadth are written in terms of just one variable. How is the total length of the fence related to the length and breadth. Write this down and subtitute from your previous result. That should give you an equation with terms where the variable is sometimes in the numerator and sometimes in the denominator. Multiply thoughout by the variable to remove it from the denominator. You now have a quadratic equation. Solve this in the required manner.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
