Rearranging capacitor charge/discharge equation
  • Thread starter Thread starter Hassss
    Capacitor
The discussion revolves around rearranging the equation for the voltage across a capacitor during its charging phase, specifically the equation Vc=Vs(1-e^-t/CR). Participants are attempting to isolate the variable t to determine the time required for the capacitor to reach a specific voltage of 26V when the source voltage Vs is 40V.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants express confusion regarding the manipulation of logarithms and the correct rearrangement of the equation. Some have attempted to apply logarithmic properties but are unsure of their correctness. Questions arise about the implications of the terms in the equation, particularly the role of the '1' in the charging equation.
There is an ongoing exploration of the rearrangement process, with some participants providing guidance on how to approach the logarithmic manipulation. Multiple interpretations of the equation are being discussed, and while some participants have made progress, there is no explicit consensus on the correct form of the rearranged equation yet.
Participants note the values of resistance and capacitance as R=100kOhm and C=100uF, which are relevant to the calculations but have not been fully integrated into the discussion of the equation rearrangement. There is also mention of confusion regarding the current during capacitor discharge, indicating a broader context of understanding needed for the topic.
Hassss
I need to rearrange the equation for exponential growth of voltage across capacitor during charging.
Equation is Vc=Vs(1-e^-t/CR) I need to find out how long it takes for Vc=26v with Vs=40v thus rearranging the equation making t the subject.
Ive forgotten what to do with Logs and therefore am stuck on this part.
LnVc=LnVs-t/CR
Im not sure if its correct but sincerely appreciate any help and advice I've calculated the time in a circuit and found t=10.4977 so need to prove it mathematically!
Thank You
LnVc=LnVs-t/CR
I'm not sure if its correct but sincerely appreciate any help and advice I've calculated the time in a circuit and found t=10.4977 so need to prove it mathematically!
Thank You
That's not a correct result.
First solve for ##\ e^{-t/(RC)} \,, \ ## then take the natural log.(Use enough parentheses to so that what you write means what you intend it to mean.)
For exponential decay i managed to rearrange it and got t=-CRlnvc/Vs from equation Vc=Vse^-t/CR (please tell me its correct)
Its just the 1-e^-t/CR that is confusing me
It's not correct.
Where did the 1 go ?
Vc/Vs = 1 - e-t/(RC) .
SammyS said:
It's not correct.
For exponential decay the equation does not have a 1- its Vc=Vse^-t/CR rearranged for t=-CRlnvc/Vs
For exponential growth it contains the 1- Vc=Vs(1-e^-t/CR) I need to make t subject for this equation
Ive managed thus so far 1+Vc/Vs=e^-t/CR in regards to logarithm rule I'm not sure what inverse of e^ is that's where I'm stuck
Dear ssss,
Your problem statement is not the statement of your problem. A clear understanding of the problem might be very helpful for you. Something like:
1. Calculate the time needed to charge an intially uncharged capacitor C over a resistance R to 26 V with a source of 40 V
And the relevant equation might well be
2. Vc=Vs(1-e^-t/CR)
What you call the problem statement only appears in the next phase, usually called:
3. attempt at a solution
I need to rearrange 2 to something that looks like t = blablabla with Vc,Vs, C and R suitably appearing on the righthand side. Then anyone with a slide rule (or, nowadays, an electronic calculator) can do the rest.
Now, having rearranged the post in this - hopefully more meaningful fashion -- what do you think would be the next step to get from 2. to blabla ?
(hint: t=-CRlnVc/Vs is no good blabla, because at t=0 Vc is still 0 and your righthand side blows up! -- or down if that's where minus infinity is).
Now, you almost admit that you have no affinity with logs, so there is a small chance you have some physics intuition to bring into this quandary and rescue you. If the 26 volt is over the capacitor, how big is the voltage drop over the resistor ? And what is the relevant equation for that Vr if you know the ones for Vs (namely Vs = 40, not much of an equation, but still...) and for Vc ?
I've managed thus so far 1+Vc/Vs=e^-t/CR in regards to logarithm rule I'm not sure what inverse of e^ is that's where I'm stuck
Maybe I should have said, Make e-t/(CR) the subject of the equation, but making something the subject of an equation is not terminology I usually use.
That result, 1+Vc/Vs=e^-t/(CR)) is not quite right.
It should be
##\displaystyle \ 1-\frac{V_c}{V_s}=e^{-t/(CR)} \ ##​
Now take the natural log (Ln) of both sides of the equation.
By the Way. [itex]\displaystyle \ln\left(1-\frac{V_c}{V_s}\right)[/itex] cannot be simplified.
Well, I propose 14/40 ...
It should be
Ive been plugging at the equation again but I've seemed to end up with this as a final.
from Vc=Vs(1-e^-t/CR)
to Vc/Vs=1-e^-t/CR
to ln(1-Vc/Vs) = ln(e^-t/CR)
to ln(1-Vc/Vs)=(-t/CR)
CRln(1-Vc/Vs)=-t
therefore t=-CRln(1-Vc/Vs)
I have tried implementing your advice into this think I've almost cracked it as the answer I'm getting is 10.49 whereas in multisim its 10.49s too so i assume its correct? :redface:
Appreciate your time and advice
hass
Kind of depends on the values R and C :smile:. OR did I overlook those ?
Sorry I never mentioned them.
R=100kOhm
C=100uF
By any chance would anyone know the equation for current during capacitor discharge.
I found this equation in my research but does not seem right at all!
i=Vse^-t/CR
Tells me during capacitor discharge i=15A :eek: Baring in mind Vs=40V
Appreciate any advice
hass
R=100kOhm
C=100uF
i=Vse^-t/CR
The correct equation should be i=(Vs/R)e^-t/CR , where Vs is the initial voltage of the capacitor.
ehild
ehild
cheers i just calculated it and got 7.77x10^-4
Also calculating current after discharge. So Vs being voltage after capacitor has discharged or initial voltage before its discharged?
thank you
thank you
Vs is the source voltage that charges the capacitor. After infinite long time, the voltage of the charged capacitor is the same as the source voltage.
In general, if the initial voltage of the capacitor is Vo, and it is discharged through a resistor R, the the current is I=(Vo/R)e^-t/(RC).
ehild
ehild
thank you for the clarification
just to ensure is this equation correct for calculating current during capacitor charging i=Vse^-t/RC
regards
Nope. Current has a different dimension, namely Volt/Ohm ! If battery is Vs and capacitor is Vc then voltage over resistor is (Vs - Vc), hence current is (Vs-Vc)/R !
This is the current that charges the capacitor: Current = charge/time and sure enough charge = Capacitance * Voltage.
We are very close to writing down the differential equation that describes the behaviour, the equation for which you stated the solution already in post #1 !
