- 8,524
- 17
It's not actually trivial that constant proper acceleration is the same as constant F, since there are two different notions of "force" in relativity, as I mentioned earlier, and you seem to be talking about "force" as defined by the derivative w/respect to coordinate time of mass*coordinate velocity*gamma, as opposed to the four-force which is the derivative w/respect to proper time of the energy-momentum four-vector. Apparently it does work out that the notion of force you're using will be constant in the case of constant proper acceleration, despite the fact that this force involves coordinate velocity and time in a single inertial frame whereas proper acceleration deals with the coordinate acceleration in a series of instantaneously comoving frames (and the proper acceleration can also be understood as the magnitude of the acceleration four-vector), but this is a nontrivial fact which requires some proof.starthaus said:For [tex]F=constant[/tex] you get [tex]v=\frac{at}{\sqrt{1+(at/c)^2}}[/tex] where [tex]a=F/m[/tex]. This is trivial.
JesseM said:Have you now abandoned the argument that this previous equation is somehow relevant to demonstrating I am wrong?
OK, then how do you think that equation was relevant? I was talking about a case involving increasing proper acceleration, whereas the previous equation [tex]v=\frac{at}{\sqrt{1+(at/c)^2}}[/tex] applies only to the case of constant proper acceleration.starthaus said:Not at all,
My "error" was only in misunderstanding what you were trying to derive, because you didn't give any explanation and didn't mention that you were no longer talking about the equation [tex]v=\frac{at}{\sqrt{1+(at/c)^2}}[/tex]. Once I realized your A was not supposed to be the same as the a in the previous equation you'd been talking about, and in fact was not supposed to refer to acceleration at all, I had no problem following what you were doing...but if it makes you feel good to crow about how you have caught me in an "error" go ahead. Can we get back to the actually relevant question though, namely how does this statement about the relation between v and A have any relevance whatsoever to showing an error in my comment to DaveC? Like I asked before: What is that supposed to prove? How is it even relevant that you defined A in terms of an integral of F/m, as opposed to just starting from the arbitrary definition A = v/sqrt(1 - (v/c)2)? How does this tell us anything about either the proper acceleration or the proper time needed to reach c?starthaus said:I didn't but in the process I have discovered that you made some other, more basic, errors.
