How Do You Calculate Width in a Changing Rectangle with Constant Area?
The discussion focuses on calculating the width of a rectangle with a constant area of 200 square meters while its length is increasing at a rate of 4 meters per second and the width is decreasing at 0.5 meters per second. The relationship between length (L), width (W), and area (A) is established through the equation LW = A. The correct application of the product rule in differentiation is emphasized, leading to the simultaneous solution of the area equation and the derived differential equation.
  • Understanding of related rates in calculus
  • Familiarity with differentiation and the product rule
  • Knowledge of solving simultaneous equations
  • Basic concepts of geometry related to rectangles
  • Study the application of the product rule in calculus
  • Learn how to solve simultaneous equations in calculus contexts
  • Explore related rates problems in calculus for better comprehension
  • Review geometric properties of rectangles and their area calculations
Students and educators in calculus, particularly those focusing on related rates and geometric applications, as well as anyone seeking to enhance their problem-solving skills in mathematics.
NewsboysGurl91
1. A rectangle has a constant area of 200 square meters and its length L is increasing at the rate of 4 meters per second. Find the width W at the instant the width is decreasing at the rate of 0.5 meters per second.
2. Know: dL/dt= 4 m/s, dW/dt=.5 m/s Want: W
3. LW=A. Then DL/dt * DW/dt = 200 m^2. How do you get W from this?
I have some other questions too. Related rates are hard.
dL/dt*dw/dt= 200 can't possibly be correct, can it? 4*0.5 is not 200! Recheck your differentiation- particularly the "product rule"! Also, it is the area that is the constant 200, not the rate of change. What is the derivative of a constant?
Never mind, I totally forgot about the product rule.
Okay, I got stuck again.
DL/dt*W+ L*DW/dt = 0.
4*W + L* -.5 = 0. How do you find L? Once you find L, isn't it obvious what W will be? Then you wouldn't have to go through this whole rate problem.
use the two equations
solve the original area equation and differential equation simultaneously
That is,
A = wl
0 = 4w - .5l
solve the above for w.
Kay, thanks.
