Relation between operators and their variables' signs
  • Context: Undergrad
  • Thread starter Thread starter hokhani
The discussion revolves around the relationship between operators and the signs of their variables, specifically in the context of differential operators and their application in quantum mechanics, such as the Hamiltonian in the Schrödinger equation. Participants explore how operators behave under transformations of their variables, questioning the correctness of expressions involving these transformations.
  • Some participants question whether the expressions for the operator ##\hat{A}(-x,-t)## should include a negative sign in front of the derivative term, suggesting that neither proposed expression may be correct unless certain symmetries are present.
  • Others clarify that an operator is a mapping from functions to functions and is not itself a function of ##x## and ##t##, although it may depend on these variables in its action.
  • There is a discussion about the Hamiltonian's dependence on time and position, with some participants noting that the Hamiltonian is an operator and not a function, which complicates the operator equations.
  • One participant proposes that if ##g(x,t) = f(-x,-t)##, then relationships between ##\hat{A}g## and ##\hat{A}f## can be established.
  • A later reply emphasizes the need for clarity regarding the context of the operator's dependence on coordinates, particularly in relation to the Schrödinger equation.
  • Another participant raises a question about the correct form of the Hamiltonian acting on ##\psi(-x)##, presenting two possible expressions for discussion.
  • Responses indicate that the resolution of such problems may involve defining a new function based on the transformation of the wavefunction, leading to differing interpretations of the Hamiltonian's action.
Participants express differing views on the behavior of operators under variable transformations, with no consensus reached on the correctness of specific expressions or the implications of operator dependence on coordinates.
Participants acknowledge the complexity of operator equations, particularly when considering time-dependent Hamiltonians and the implications of spatial inversions on wavefunctions. There are unresolved questions regarding the definitions and dependencies of operators in various contexts.
hokhani
TL;DR
Do differential operators change corresponding to their variables' signs?
Consider the operator ##\hat{A} (x,t) =\frac{d}{dx} +f(x,t)## where ##\hat{A}## is an operator and ##f(x,t)## a function. I don't know which of the following expression is correct for ##\hat{A} (-x,-t)##?
first one: $$\hat{A} (-x,-t) =\frac{d}{dx} +f(-x,-t)$$ and the second: $$\hat{A} (-x,-t) =-\frac{d}{dx} +f(-x,-t)$$
My take:
$$\hat{A}(-x,-t) = \left.\frac{d}{dx}\right|_{-x} + f(-x,-t)$$
Unless the function acted upon by ##\hat{A}(x,t)## possesses any symmetries, I'd say neither of your suggestions are correct.
hokhani said:
TL;DR Summary: Do differential operators change corresponding to their variables' signs?
An operator is a mapping from functions to functions. It's not itself a function of ##x## and ##t##.
Of course in general an operator can be a function of the coordinates; e.g., the 3D Laplacian in spherical coordinates:$$\nabla^{2}=\dfrac{1}{r^{2}}\dfrac{\partial}{\partial r}\left(r^{2}\dfrac{\partial}{\partial r}\right)+\dfrac{1}{r^{2}\sin\theta}\dfrac{\partial}{\partial\theta}\left(\sin\theta\dfrac{\partial}{\partial\theta}\right)+\dfrac{1}{r^{2}\sin^{2}\theta}\dfrac{\partial^{2}}{\partial\phi^{2}}$$
That's not a function of coordinates. It uses a coordinate function such as ##r^2## as part of its action on a function. The input to the Laplacian is a function and the output is another function.
OK, mea culpa! Yes, I was using "function" in the colloquial sense of "having a dependence on" the coordinates. Since a function by definition takes numbers into numbers, something taking functions into functions is indeed a different beast. Labeling it a "mapping", I modify my previous statement to simply note that this function-to-function "map" may well depend upon the coordinates.
If ##g(x,t) = f(-x,-t)##, then we could relate ##\hat Ag## to ##\hat Af##.
In mathematical language, as you said, an operator is not a function of ##(x,t)##. However, the operator depends on x and t. If we cannot write this dependence as ##H(x,t)##, how to show this dependence in an operator equation?
Can you be more specific about the context of the question?
Of course; in the Schrödinger equation we have something like: ##H(x,t)\psi(x,t)=i\hbar \frac{\partial }{\partial t} \psi(x,t)## which at each space-time point, ##(x,t)##, only the Hamiltonian ##H(x,t)## acts on ##\psi(x,t)##. I try to understand why ##\psi(x,-t)## is not the answer of ##H(x,-t)##?
The Hamiltonian may depend on time, which means you do not have a simple operator equation. The Hamiltonian itself does not depend on position. The Hamiltonian is an operator. It's not a function.
Let's take the example of a time-independent Hamiltonian. This can be written in the form of an operator:
$$\hat H = -\frac{\hbar^2}{2m}\hat D^2 + \hat V$$We have used ##\hat D## to denote the differential operator and ##\hat V## to represent the operator generated by multiplication by some (potential) function ##V##.
The action of this operator on a function, ##\psi## is:
$$\hat H\psi = -\frac{\hbar^2}{2m}\hat D^2\psi + \hat V\psi$$Finally, we can use ##x## and ##t## as the position and time variables for our functions and express this equation for every point ##x## and time ##t##:
$$(\hat H\psi)(x, t) = -\frac{\hbar^2}{2m}\frac{\partial^2\psi}{\partial x^2}(x, t) + V(x)\psi(x, t)$$If the potential is also a function of ##t##, then we have a time-varying equation:
$$(\hat H\psi)(x, t) = -\frac{\hbar^2}{2m}\frac{\partial^2\psi}{\partial x^2}(x, t) + V(x,t)\psi(x, t)$$In this case, you could write the Hamiltonian itself as a function of time:
$$\hat H(t) = -\frac{\hbar^2}{2m}\hat D^2 + \hat V(t)$$
Great answer, many thanks.
Sorry for returning again to this question, I would like to be certain. So, I raise another question:
For the general form of the Hamiltonian in one dimension, ##H=P^2/2m +V(x)##, which of the following is correct for ##H\psi(-x)##?
$$ (1): \\
H\psi(-x)=(P^2/2m +V(x)) \psi(-x)$$ or $$ (2): \\
H\psi(-x)=(P^2/2m +V(-x)) \psi(-x)?$$
The way to resolve such problems is to let:
$$\phi(x) \equiv \psi(-x)$$That's technically what ##\psi(-x)## means. That the wavefunction is a composition of the function ##\psi## with the function ##x\to -x##. That is case (1).
However, you might also have the case of a general spatial inversion ##x \ to -x##. That is case (2) where you have a general change of coordinates.
  • · Replies 32 ·
  • · Replies 17 ·
