Relationship between molecular orbitals and normal modes
21 replies · 4K views · last reply
lucas_
I'd like to ask a couple of questions.
As a solid object gets bigger, the molecular orbital (combinations of all single atom orbitals) has greater size too? For a one inch square object (of closely packed molecules like crystals), what is its molecular orbital size compared to a one foot square crystal object?
Second. When photons hit an object and the molecules. They are absorbed as molecular vibrations and redistribution into normal modes. The molecular orbital is not affected because you need much higher energy photons to affect the electronic orbitals. So what is the connection of molecular orbital to molecular vibrations?
Yes, you may think of the molecular wavefunctions to extend over the whole crystal, although this has hardly observable consequences. I.e., you could also assume that they extend only over say 1 ##\mu##m. Remember that molecular orbitals are rather a theoretical construct than a physical reality. For many types of solids, e.g. isolators, you could use alternative descriptions, like Valence Bond theory which use atomic orbitals and get equal results.
Second: In the Born Oppenheimer approximation, the molecular orbitals depend parametrically on the position on the nuclei and this is also the mechanism they generate a potential for the motion of the nuclei.
Raman and IR Spectroscopy deal directly with the molecular vibrations. I was asking what is the use of knowing the molecular orbital.. would these affect intermolecular bonding? is there some spectroscopy that deal with them?
Do you mean by the statement above:
In each instant of time, the electronic energy depends on the instantaneous positions of nuclei and also this electronic energy is a potential term for nuclear Hamiltonian?
Yes, exactly.
So understanding molecular orbits is sort of making bookkeeping of he nucleus positions. But what happens when you introduced energy to it in the form of photons. Do we need solely gamma rays to affect the molecular orbital or do low frequency IR can affect it too. What is the relationship between thermal properties of the molecules with reference to the molecular orbital? Can you store energy in the molecular orbitals and transfer these thermal energy to the molecular vibrations?
IR won't induce transirions between electronic states, but visible or UV light may.
Why don't you read an introductory text on spectroscopy?
I was familiar with spectroscopy as it relates to vibrational modes of the molecules. But I'm not familiar with spectroscopy that deals with molecular orbitals. What are the ways to turn Bonding orbital into Antibonding orbital disentangling the molecules (or reforming them at other configurations)? Do we study Molecular Orbitals to understand bonding solely or is it active such that we can send photons to them manipulating the nuclei?
[QUOTE="lucas_, post: 5014565, member: ]Do we study Molecular Orbitals to understand bonding solely or is it active such that we can send photons to them manipulating the nuclei?[/QUOTE]
Yes, look up photochemistry and pump probe spectroscopy.
Dr.Du I studied all your recommendations and I came across Vibronic Coupling and have a couple of questions (I have studied it too).
Most molecules can be analyzed via the Bohr-Oppenheimer Approximations. Does it mean Vibronic Coupling is active in all molecules and we just ignore it mostly? or do the latter only exist for certain molecular combinations? Can you give a more everyday example such as NaCl? Do all objects have vibronic coupling? How do you distinguish what objects have it or not? Most of what I read about it is that vibronic coupling is difficult to analyze hence ignored.
Vibronic coupling definitely is important in spectroscopy. I would distinguish at least two different kinds: In the first one, the nuclear coordinate dependence of the Born-Oppenheimer wavefunction plays a role. Specifically, the wavefunction can be expanded around the equilibrium position ##R_0##: ##\psi(R,r)=\psi(R_0,r)+(R-R_0)\psi'(R_0,r)+\cdots##. The dependence on the nuclear coordinate ##R-R_0## can make an otherwise electronically forbidden transition allowed. This is common in d-d transitions and responsible for the bluish colour of copper sulphate or rose colour of manganum (II) salts.
The second kind of effect corresponds to non-adiabatic coupling beyond the Born Oppenheimer approximation. This is usually not so important for the ground state but of high importance for excited states. Namely it leads to the very fast radiationless decay of electronically excited states back to the ground state. In this process the electronic excitation energy is converted into vibrational quanta and so into heat, at the end.
This coupling is responsible for the fact that there are only few strongly fluorescent substances.
Which of the two kinds occur in daily common substance like silicon, carbon, hydrogen for instance? We commonly ignored electronic transition in the equipartitions of energy and just focus on vibrational, translational and rotational degrees of freedom. Does vibronic coupling entail that in ALL substances, there is a contribution of the electronic degrees of freedom in the heat capacity but just ignored due to the very tiny values? I want to know how to tell what substance (and how to tell which) Is sensitive to vibronic coupling if this is not present in all substances. Thank you.
Vibronic coupling has practically no influence on the thermodynamic properties of materials for several reasons:
1. The excited electronic states are energetically too high to be excitable by thermal energies.
2. The Born-Oppenheimer approximation is very good for the ground state.
3. Even for the thermodynamical properties of excited states, the vibronic coupling plays only a minor role due to some variant of the Bohr van Leeuven theorem.
The following article is the specialists reference on vibronic couplings:
Köppel, H., W. Domcke, and L. S. Cederbaum. "Multimode Molecular Dynamics Beyond the Born‐Oppenheimer Approximation." Advances in Chemical Physics, Volume 57 (2007): 59-246.
The above reference is not available but I tried to search other materials and topics like conical intersections and actually read it, and it seems there is not a lot of materials for laymen available. I think vibronic coupling is related to photochemistry since electron transition is sensitive to visible and UV light. In the human body and biochemistry what parts is sensitive to such vibronic coupling? What particular chemical reactions? Do you believe it can either suppress or accelerate chemical reactions? Can you give an obvious example. Thanks.
There are two important photochemical reactions in the body: the cis-trans isomerisations of retinal in the light receptors in the eye and vitamin D synthesis.
Are you saying vibronic coupling is not important for non photochemical applications? I read that any chemical reactions sensitive to conical interactions will be sensitive to vibronic coupling. Aren't there any chemical reactions in the body (like enzymes) that have conical interactions (ignoring photochemical stuff like retina or vitamin D)? From memory.. what chemical reactions can you give by rule of thumb that is sensitive to conical interactions (http://en.wikipedia.org/wiki/Conical_intersection)?
I'm still a bit confused how to distinguish.
Hope others like atty can assist too. Thanks.
I can't think of anyone. While there may be conical intersections between the ground and excited PES, these are not thermally accessible. The only case where CI's are of some importance for the ground state is in the case of the Jahn Teller effect although even there, the nuclear vibrations won't reach the CI.
DNA is sensitive to it. http://en.wikipedia.org/wiki/Conical_intersection
"For example, the stability of DNA with respect to the UV irradiation is due to such conical intersection.[1] The molecular wave packet excited to some electronic excited state by the UV photon follows the slope of the potential energy surface and reaches the conical intersection from above. At this point the very large vibronic coupling induces a non-radiative transition (surface-hopping) which leads the molecule back to its electronic ground state."
I don't like outdoors. So if our body needs to be exposed to natural sunlight and some UV to activate our DNA and genes. Then I need to make huge effort to go outdoor. Studying this would give me the motivation. Are you sure our DNA doesn't need constant exposure to light to be optimum? Why is our DNA sensitive to conical intersection?
DrDu said:
But you were asking for non-photochemical reactions?
What? But DNA thing is a non-photochemical reaction. Do you consider it as photochemical? I seemed to read that many chemical reactions can have vibronic coupling. Are you saying only photochemistry reactions can support vibronic coupling? Or maybe there are many materials or substance that we don't know are photochemical active? (those with conical intersection)?
There seems many concept. Photochemical active vs non-photochemical active. Excited states and ground states. I'm including excited states in the conical intersection thing. So if they can be in excited states.. you include DNA as suppoting conical intersection? What other chemical reactions in the body have conical intersection in the *excited* state part?
The dimerisation of Thymidine in DNA after UV irradiation is clearly a photochemical reaction. And no, our DNA really doesn't need UV irradiation for its correct function, just on the contrary. Our body only needs moderate values of UV-B radiation to produce vitamin D, but even this can also be substituted by nutrition rich in vitamin D, like fat fish. You are right here: Vibronic interactions is really a huge field.
This means also that it is virtually impossible to provide you a neat introduction into the field in some posts here in the forum.
Unfortunately, I also don't know of any textbook which provides a neat introduction into the field, at least to the newer research on conical intersections. However, stuff like intensity borrowing in the spectroscopy of d-block element compounds should be available in most books on spectroscopy. If you are really interested you need a good background in quantum mechanics or quantum chemistry and be prepared to get some articles from your library.
Maybe you find this book:
Domcke, Wolfgang, David Yarkony, and Horst Köppel. Conical intersections: electronic structure, dynamics and spectroscopy. Vol. 15. World Scientific, 2004,
which sums up the work of all the experts on this field on CI, and photochemical reactions involving nonadiabatic effects.
Btw, I did my PhD thesis on this field, so I might help you with some specific problems.
@DrDu
Could you help me with literature about interaction of photon and de localized pi-electrons,actually I am interested in photon interaction and MO.
There are lots of books but I would now which one would cover this topic.
Thank you
