Relationship between spectral distribution and Compton scattering
This discussion revolves around the relationship between spectral distribution and Compton scattering, as part of a modern physics module. The original poster expresses uncertainty regarding spectroscopy and the Lorentzian profile, while having some familiarity with Compton scattering. They inquire about how spectral distribution relates to Compton scattering and the correspondence of variables in the relevant formulas.
  • Participants discuss the need to understand the Lorentzian distribution in the context of Compton scattering, questioning how the spectral distribution of x-rays relates to the scattering process. There are inquiries about the meaning of "output graph" and the implications of the narrow line-width in the spectral distribution.
Some participants suggest looking for relevant course materials on Lorentzian profiles and exploring the implications of the distribution of frequencies in Compton scattering. There is a recognition of the need for clarity regarding the definition of "spectrum" in the context of the problem, with multiple interpretations being explored.
Participants note that the original poster's syllabus does not cover the Lorentzian profile, which may limit their understanding. There is also mention of the need to clarify the values and units used in the problem, as well as the potential distinction between intensity and energy in the context of the spectrum.
Baal Hadad
You have an x-ray source with photon energy of 17 keV and has a spectral distribution which follows a Lorentzian profile with a full width at half maximum of 0.1 eV.
L=L0/(1+2((w-w0)/delta w)^2)
with w=frequency, w0=central frequency (corresponding to the energy, E), delta w=FWHM,L0=1
Show for the Compton formula showing how the spectrum changes
with the detection angle. Show the output graph for theta = 0-180 degrees with an increment
of 5 degrees.
Compton scattering formula: delta lambda=(h/(m_e*c))(1- cos theta)
First of all, this is question from the modern physics module in 1st year physics program. The problem is I have no prior knowledge about spectroscopy or Lorentzian profile. However, the Compton scattering topic was already introduced.
The Compton scattering formula can be changed into the form:
delta(1/f)=(h/m_e*c^2)(1- cos theta)
The w in the homework statement corresponds to omega.
My question is: How is the spectral distribution related to the Compton scattering? Which variable in the Compton scattering formula corresponds to which variable in the Lorentzian profile? Is the spectral distribution produced by the photons emitted by the electrons after Compton scattering?
And also in the question stated omega is the frequency but normally omega is the symbol of angular frequency, so I am not sure that whether omega is frequency or angular frequency.
Thanks.
Your first priority is to find the relevant course material on a Lorentzian distribution/profile. Or try online.
You've probably studied Compton scattering for a given frequency/wavelength. This problem is asking you to study it for a distribution of frequencies. The incident x-rays have a distribution of frequency (Lorentzian), hence the x-rays scattered at an angle ##\theta## will also have a distribution of frequency.
For each ##\theta## you are asked to calculate the scattered frequency distribution.
You'll also have to find out what precisely is meant by "output graph". I can't help you there, I'm afraid.
Do you have any suggestions on course on Lorentzian profile? Fotr now the syllabus I studied only covered until Krane's Chapter 2 to 5 at most.
Sorry, I haven't worked with it. Are you self-studying?
No, I am not self-studying. But Lorentzian profile is never on the syllabus in the module"Modern Physics", since the lectures are almost based on topics from Krane.
You need to ask your course provider for an appropriate reference. The Wikipedia page looks quite general, but you may be able to deduce from that precisely what distribution you have in the question.
https://en.wikipedia.org/wiki/Cauchy_distribution
I asked him and he asked me to search the internet myself. Never mind,maybe I will search myself, thanks.
Someone else on here is sure to know a lot more about it. Maybe you'll get a better answer later. Good luck!
Although I've never learned about Lorentzian profile, I'd like to have a guess.
$$L = \frac{1}{1+2(\frac{\omega - 17\,KeV/\hbar}{0.1\,eV/\hbar})^2}$$
This profile is just a function of ##\omega##. First we have a series of ##\omega## range from 0 to ##\infty## and can generate a profile (a function). Then, after Compton scattering ##\omega##'s change to new ones with a one-to-one correspondence (dependent on ##\theta##). Then, maybe what you need to do is to plot the old ##L## with new ##\omega##'s and see what happens.
The question seems to be a computational (not analytical) one? I feel that it is OK to generate figures by MATLAB or something.
This profile is just a function of ##\omega##. First we have a series of ##\omega## range from 0 to ##\infty## and can generate a profile (a function). Then, after Compton scattering ##\omega##'s change to new ones with a one-to-one correspondence (dependent on ##\theta##). Then, maybe what you need to do is to plot the old ##L## with new ##\omega##'s and see what happens.The question seems to be a computational (not analytical) one? I feel that it is OK to generate figures by MATLAB or something.
Well, thanks for you reply.
My lecturer asked for Python coding, so I think MATLAB cannot be used.
And also, do you mean that:
$$ \omega=\omega_i=\frac{1}{\frac{1}{\omega_f}-\frac{h}{m_e c^2}(1-\cos{\theta})} $$
But using Desmos to plot gives me a straight horizontal line at 0. Maybe I will check again...
EDIT: Found the peak but on the frequency is on the magnitude of 10^18, I guess this is why the graph produced is problematic.
Baal Hadad said:
Homework Statement:: You have an x-ray source with photon energy of 17 keV and has a spectral distribution which follows a Lorentzian profile with a full width at half maximum of 0.1 eV.
of 5 degrees.
Relevant Equations:: Compton scattering formula: delta lambda=(h/(m_e*c))(1- cos theta)
I’m on the limits of what I know, but here are some thoughts.
E = 17keV and ΔE = 0.1eV = 0.0001keV.
Such a narrow line-width seems unlikely. The results would probably be indistinguishable from a monochromatic 17keV source. Are you sure you have values/units correct? Or maybe you are meant to realize this (monochromatic approximation) for yourself?
The question states “Show for the Compton formula showing how the spectrum changes
with the detection angle.” This doesn’t make 100% sense grammatically.
You need to be sure you know what ‘spectrum’ means in this context; it could mean:
a) intensity at different angles;
b) photon energy at different angles.
If b), you would just use your ‘Compton formula’ to find the energy at different angles.
But if a), it’s much harder. The intensity at a given angle corresponds to what is called the differential cross-section at that angle. So it would mean you are being asked to find the differential cross-section (for 17keV Compton scattered photons) at different angles. This requires a special (relativistic) formula called the Klein-Nishina formula. You will have to look this up if required. However the photon energy (17keV) is quite a lot less than the electron rest-energy (511keV) so, to a decent approximation, you could treat this as non-relativistic and the Klein-Nishina formula simplifies (to give Thompson scattering).
Note that the equation$$L=\frac{L₀}{1+2(\frac{ω - ω₀}{Δω})^2}$$ gives all the information about the shape of the source’s spectrum. You can use the formula without knowing anything else about it. (Assuming you need to use it with such a narrow line-width.) The fact that it’s called ‘Lorentzian’ is unimportant/irrelevant. But if you wanted to know, out of interest, what Lorentzian means look here for example : https://en.wikipedia.org/wiki/Spectral_line_shape
Angular frequency (ω), conventional frequency (f) and photon energy (E) are mutually proportional so we can write the above equation with f or E substituting for ω (conversion factors cancel).
With energy in keV and the given values this gives $$L=\frac{1}{(1+2(\frac{E – 17}{0.0001})^2}$$(Less messy than working Hz)
But, as already noted, this is such a narrow line (assuming your values are correct) that you might as well treat the X-rays as monochromatic. This would mean you don't use the above formula.
Thank you for your reply.
Firstly, the values 17keV and 0.1eV are as in the original question.
For the grammatical problem, the original question is worded as:" Write a code showing for...", with the rest followed word-by-word as in the homework statement.
For the context of the word "spectrum", I don't know either. No any previous context is given before this question. Maybe I will ask my lecturer to clarify.
So, if "spectrum" means photon energy at different angles, does this means that I can substitute the Compton formula into the spectral function and will have the variables ##\omega_i## for initial frequency of photons in Compton scattering and the scattering angle ##\theta## for the new spectral function?
No. That won't work. See if this makes sense...
It is not difficult to use the Compton formula to get an expression for the energy of a scattered photon (Eₛ). You end up with$$\frac{1}{E_s} = \frac{1}{E_i} + \frac{1}{m_ec^2}(1 - cosθ)$$where Eᵢ and Eₛ are energies of the incident and scattered photons.
Since the electron’s rest mass is 511keV, working in units of keV gives:$$\frac{1}{E_s} = \frac{1}{17} + \frac{1}{511}(1 - cosθ)$$$$E_s = [{\frac{1}{17} + \frac{1}{511}(1 – cosθ)}]^{-1}$$You can then use this formula to find values of Eₛ at different angles. Then plot Eₛ vs. θ.
We are treating the source as monochromatic (every incident photon is exactly Eᵢ = 17keV). As a result, each angle has a unique value of Eₛ. That’s important to understand.
Now, for the purposes of explanation, let’s suppose the source is not monochromatic but has a wide spread of energy, e.g. ΔE = 3keV.
Some of the incident photons will be Eᵢ=17.9keV, or Eᵢ=20.2keV or Eᵢ=15.2keV for example. That means there is a wide range of possible incident energies and, for a given value of θ, there is a correspoinding wide range of possible scattered energies. We cannot draw a graph of Eₛ vs. θ because there isn’t a unique value of Eₛ for each value of θ.
This means, unless we have a monochromatic source, a graph of Eₛ vs. θ is meaningless; so it cannot be what is meant by ‘spectrum’.
You need to find out:
a) what is meant by ‘spectrum’. The x-axis is angle, but what is the y-axis?
b) is ΔE really 0.1eV? And, if so, can you treat the X-rays as monochromatic?
You can’t really get any further unless you have answers to these questions.
It would also help to know what your have covered. Do you know what a scattering cross-section is? Have you covered Thomson and Kline-Nishima scattering formulae?
Sorry I can’t assist more at this stage. If you can get answers to the above questions, I’ll try to help some more.
I tried this approach before and get a nice graph with peak at 1 actually, but my coursemates think elsewise, so I decided to ask somewhere for further clarification. Maybe I am right at the beginning...
By the way, maybe a 2 variable graph is expected, by changing ##\theta## using an external slider.(This problem should be solved using coding so this is possible).
For the meaning of "spectrum" I am still waiting the reply from my lecturer.
I am quite sure that the value written on the exercise is 0.1eV, but whether the lecturer ask us to assume that this is a monochromatic source is not known.
I know nothing of the topics you mentioned above. In this introductory module, the class until now only covered Chapter 5 of Krane (very basic SE) with several topics skipped.
Thank you for your assistance until now. I think that maybe any progress can be done only after the reply from my lecturer.
10K
  • · Replies 24 ·
  • · Replies 0 ·
