Relative momentum and relative mass
57 replies · 7K views
Amr Elsayed
Hi all,
I feel like I have a misconception about that topic, so I hope I will get an answer for the question:
Momentum should be conserved from the same perspective, but does it have to from different perspectives or frames ? I mean we don't agree about sth's velocity, so we don't agree about momentum. What's wrong with that?
what I know is that mass changes from different frames is because each frame should observe the same momentum.
regards
Nothing. Both momentum and energy are frame dependent quantities.
Then why there is a need for mass to change due to special relativity laws ?
I mean mathematically concerning momentum , Momentum and velocity are relativistic, then why mass is ?
It's how the measurement of momentum changes as seen from different frames that distinguishes Newtonian physics and Relativity.
In the former, momentum can be measured as mass times velocity. This is frame dependent because an object's momentum as measured by any frame is dependent on its velocity with respect to that frame.
In Special Relativity, momentum is measured as mass times velocity times the Lorentz factor of [itex]\frac{1}{\sqrt{1-\frac{v}{c^2}}}[/itex]
Since the Lorentz factor depends on the velocity, the increase of momentum with an increase of velocity is not linear under Special Relativity like it is under Newtonian physics.
And why do we multiply it with Lorentz factor ?
It is not, at least not in the sense most physicists use the term. See our FAQ https://www.physicsforums.com/threads/what-is-relativistic-mass-and-why-it-is-not-used-much.796527/
If we did not it would violate Lorentz invariance, i.e., the statement that the physics are described by the same equations in all inertial frames.
Would you please illustrate more ? why?
Which part of the statement do you have problems with?
In general, depending on your level, it may be more fruitful to think of things in terms of the classical expressions being only approximations to more general ones.
I need to know what's different about momentum since we discovered time dilation. How this affects mass
it's not because we discovered time dilation - both time dilation and the relativistic momentum equation come from the Lorentz transformations, which are a consequence of the speed of light being finite and the same for all observers.
And it's not that anything was suddenly "different about momentum" after we discovered the Lorentz transforms. The momentum of a moving object has always been ##p=\gamma{m}_0v## and ##p={m}_0v## has always been just a very good approximation - so good, in fact, that it was several centuries before we figured out that it wasn't exact.
If the speed of light were infinite, then ##p={m}_0v## would be exact.
Thank you, but I still want to know the mathematical and physical proof of mass change due to special relativity. I mean without mass changing " In my frame" momentum is conserved, and in the frame of any moving object it's conserved too. What is need for mass to change? or it's possible not necessary ?? You can tell me why P= gama*m*v
Sorry for bothering
regards,
Did you read the FAQ I linked? Mass does not change in relativity.
The "mass" that changes is relativistic mass, which is just another word for "energy". Do you understand why an object's energy changes when its velocity changes?
I quickly did, but it was about how physics consider mass. I mean mass that is the resistance of the substance to accelerate.
I don't, sir. Just more kinetic energy is that i know, do you mean sth else ?
You should read it more carefully. It is about why relativistic mass is not a concept used by physicists. Therefore, we generally only talk about the rest mass. I also suggest you take post #12 to heart and think about it. There is a lot of useful material there.
In other words, you mean inertia (or "inertial mass"). If that's what you're interested in, you shouldn't be looking at just energy and momentum; you should be looking at force, to see how much acceleration a given applied force imparts to an object which is already moving at a given velocity. In other words, you should be looking at the relativistic equivalent of ##F = m a##. See, for example, here:
http://en.wikipedia.org/wiki/Four-force
What you will find is that "relativistic mass" is not a useful concept for understanding inertia in general in relativity; it's better to focus on invariant mass (i.e., rest mass, i.e., what relativists mean when they say "mass") and how it appears in the various equations involved.
Just to add that this ...
... is also covered in the FAQ.
Thank you but it's not my problem, I want to learn about relativistic mass, I heard sth like we know it changes because of relativity and conservation of momentum
When an object's in a free fall for example due to gravity it will accelerate but will not reach c, They say because mass increases. I think this relates
Well, I want to understand what relativistic mass is if i will not waste your time
It is not our time you would be wasting, it is your own. If you want to learn why resistance to acceleration changes with velocity and is different in different directions, the answer lies in the relativistic expression for momentum - as outlined in the FAQ. It is generally not what is called relativistic mass, which as noted before is just another way of saying "total energy" in relativity.
This has nothing to do with "relativistic mass". First of all, an object in free fall is not accelerating in any physical sense--its proper acceleration is zero. Its "acceleration" is coordinate acceleration, which is, as the name implies, coordinate-dependent; you can eliminate it by picking appropriate coordinates (those of a local inertial frame). So this is not at all analogous to an object undergoing proper acceleration in flat spacetime, but never reaching c relative to some fixed inertial observer.
Unfortunately FAQ doesn't contain the proof for the increasing relativistic mass. I need a proof like: C is constant so there is length contraction and time dilation with equations. I think trying to understand sth is not time wasting :)
I just meant velocity increasing for a fixed frame of reference like the ground. If I fall in a planet that gives enough height and time to reach C ? increasing velocity will continue because of acting force. Why wouldn't it reach C then ?
It contains perfectly fine argumentation that based on ##\vec p = m\gamma\vec v##, the force required to accelerate an object will depend on both direction and speed. It also states why relativistic mass is obsolete as a concept and not directly related to inertia. The reason that momentum appears the way it does is that it is the spatial part of a 4-vector, which transforms in a very particular way under Lorentz transformations.
You should leave gravity out of the discussion for now. Gravity is not a force in relativity and requires general relativity for a proper treatment. Why an object does not reach c even after having a constant force acting on it for a very long time is explained in the FAQ.
Amr Elsayed said:
Thank you, but I still want to know the mathematical and physical proof of mass change due to special relativity...You can tell me why P= gama*m*v
You will find a bunch of derivations if you google for "relativistic momentum derivation". Try reading a few, and if you still can't see why ##p=\gamma{m}_0v## is the correct expression for momentum, try asking some more specific questions and we can help you over the sticking point.
Note that these will be derivations of the relationship ##p=\gamma{m}_0v##. More than a century ago, physicists took a wrong turn when they interpreted that equation as saying that there's a "relativistic mass" defined by ##m=\gamma{m_0}## and you just have to use the relativistic mass instead of the rest mass to make the old ##p=mv## work. It took many decades to get back on track after that wrong turn, and during those decades many textbooks were written and many popularizations were published... So to this day, you'll hear people saying "mass increases with speed". But that is not what modern physics says.
But this "fixed frame of reference" is not an inertial frame, and does not work like an inertial frame in SR. (And acceleration relative to it is coordinate acceleration, as I said.)
"Reach C" has no meaning as it stands, because, as above, this "fixed frame of reference" is not an inertial frame.
0:52 for example
It's talking about 2 different frames
I think like" You are considering 2 different times for 2 different frames, P must be equal for only the same frame !" That's my story with derivations
I have searched about it again in Haliday. I found that relativistic momentum is measuring velocity with distance measured by an observer (at rest) and time is measured by the moving object itself, how come ? I mean velocity should be determined as a single observer observe it.
It's also saying that total momentum is not conserved if we use classical law of momentum. I think I need an example for this, or I will give it my self
Suppose a car moving with 0.8 C with a mass of 100 kg crashes into a wall with a mass of 1000 kg
If I'm at rest according to the wall,then momentum before crash is 100kg*0.8 C, and after crash the car will go backward with a momentum of 100kg*0.8 C
If I am at the car, Momentum of moving wall" according to me" is 1000kg* 0.8 C and the same after since I will see the wall going forward
I will need to change mass if I calculate velocity as d/t where d is distance measured by me if I'm at rest according to wall and t is time needed to cut the distance according to car !
