Relativistic Kinetic Energy: Does Mass Change?
3 replies · 2K views
Weam Abou Hamdan
Hello,
According to Special Relativity, the mass of an object must increase as its speed approaches the speed of light.
m=m0γ
In the formula that allows us to calculate the kinetic energy of a body, KE=0.5mv2, should we take into consideration such increase in mass?
Weam Abou Hamdan
Wednesday, August 22, 2018
Weam Abou Hamdan said:
Hello,
m=m0γ
That ##mv^2/2## formula for the kinetic energy is a classical approximation that only works at speeds that are small compared the speed of light. The correct relativistic expression for the kinetic energy is ##(\gamma-1)m_0c^2## where ##\gamma=1/\sqrt{1-\frac{v^2}{c^2}}## and ##m_0## is the mass of the object when it is at rest. (It would be a good exercise to confirm that this expression approaches ##mv^2/2## when ##v## is small compared with ##c## - expanding ##\gamma## in a power series in ##v/c## will do the trick).
Although you'll hear that bit about the mass of an object increasing a lot, this idea has been largely abandoned in recent decades - there are better ways of describing what happens. This comes up so often that we have an Insights article: https://www.physicsforums.com/insights/what-is-relativistic-mass-and-why-it-is-not-used-much/
Even as early as Einstein the concept of relativistic mass has been recommended against. Here is a good paper on the topic:
https://arxiv.org/abs/physics/0504110
Hello,
m=m0γ
Weam Abou Hamdan
Please stop thinking about relativistic mass. Instead, find out what proper time is, and use the quantity t/γ as time and do the normal kinematic derivation of kinetic energy. The γ will end up giving you the relativistic kinetic energy formula.
Using t/γ as time:
Divide x by t/γ
Miltiply by m to get relativistic momentum
Take the derivative with respect to t to get force
Integrate over distance (changing the variable to v) to get relativistic kinetic energy.
Basically the same thing you’d do in non-relativistic physics but starting with t/γ instead of t.This old post by a site mentor goes through it more concisely:
https://www.physicsforums.com/threads/derivation-of-relativistic-energy.63380/#post-458653
