Understanding Relativistic Momentum in Special Relativity
The discussion centers on the concept of relativistic momentum in special relativity, specifically the equation p=γmv, where γ (gamma) represents the relativistic factor. Participants clarify that while invariant mass (m) remains constant, the relativistic mass (γm) increases as an object's velocity approaches the speed of light. This leads to the conclusion that a constant force results in diminishing acceleration due to the increasing relativistic mass, preventing any object from reaching or exceeding the speed of light. The conversation also highlights the importance of not mixing different conventions regarding mass in relativity. Ultimately, understanding these principles is crucial for grasping the implications of special relativity on momentum and force.
DRC12
Last week in physics we were learning about special relativity and we got the equation p=λmv. When writing the equation the teacher also put the equations for regular momentum p=mv and regular force F=ma. I noticed that momentum is the integral of force where v is the integral of a and mass is constant. The problem is if momentum is the integral of force then how is the relativistic momentum derived is mass isn't constant anymore
In the formula for relativistic momentum, p=λmv, m is the invariant mass and is constant.
[Edit: That should be γ not λ.]
but if m is constant an object could theoretically go faster then the speed of light all you need is to supply a constant force on it and it would accelerate forever the changing m making it harder to accelerate the object once it starts going too fast. As m increases the force does less in less until it can't accelerate no matter the force on it as in the mass eventually reaches infinity
Note that I said that m is constant. But λm (sometimes called the 'relativistic mass') is not constant.
There are two different conventions.
An older convention is to consider mass as changing. Then F=ma and p=mv, and a constant force produces less and less acceleration as you approach the speed of light, because m is increasing.
The more common convention these days is to consider mass as constant. Then F=m\gamma a, F=dp/dt, and p=m\gamma v. Now a constant force produces a decreasing acceleration because of the factor of gamma. (If your teacher is using lambda instead of gamma, that would be an unusual notation.)
You can't mix the two systems.
You can show that a constant force would take an infinite amount of time to accelerate a massive object to the speed of light. In fact,
\int_0^T F dt = \int_0^c \frac{m dv}{(1-\frac{v^2}{c^2})^{3/2}} = mc \lim_{v\rightarrow c} \frac{1}{\sqrt{1-\frac{v^2}{c^2}}},
which diverges. The LHS gives FT so T must be infinite.
He did use gamma i just mixed them up
And I didn't even notice--in my mind I was thinking gamma (γ) not lambda (λ). :redface:
Sorry about that!
Sorry about that!
No problem I'd been looking at light waves earlier today and had been using lambda as frequency and used it without thinking
Thanks to everyone I understand it now I didn't think about how gamma wasn't a constant or how gamma was expressing the change in the rest mass and I wasn't thinking of it as rest mass
  • · Replies 19 ·
  • · Replies 67 ·
  • · Replies 114 ·
11K
  • · Replies 0 ·
  • · Replies 36 ·
