Graduate How Large is the Residual Error in FEA Solutions of PDEs?
  • Thread starter Thread starter feynman1
    Fea Pdes
The discussion focuses on the residual error in finite element analysis (FEA) solutions of partial differential equations (PDEs) solved through Newton iteration. Key points include the relationship between the residual error of the PDE and the finite element discrete system, the use of Gaussian elimination for solving element equations, and the impact of mesh refinement on convergence. It is established that the error decreases as mesh size reduces, but complications arise with highly oscillatory solutions and unstructured meshes, which can hinder convergence.
  • Understanding of finite element analysis (FEA)
  • Familiarity with Newton iteration methods
  • Knowledge of Gaussian elimination techniques
  • Concept of residual error in numerical methods
  • Explore Richardson extrapolation for error estimation in FEA
  • Study the effects of mesh refinement on convergence in nonlinear PDEs
  • Investigate the Gibbs phenomenon in numerical solutions of oscillatory PDEs
  • Learn about iterative solvers and their convergence criteria in FEA
Researchers, engineers, and practitioners involved in numerical methods, particularly those working with finite element analysis and solving partial differential equations.
feynman1
A PDE is solved by finite elements. The PDE then becomes a discrete system solved by Newton iteration. Every iteration step comes with a residual error. When the solution is completed, how far is the residual error of the PDE from the residual error of the finite element discrete system?
I thought the residual error minimization and trial functions come into play deriving the element equations which are then solved by Gaussian Elimination.
If the discrete system is nonlinear, either iteration is needed or linearization is to be done? Which is more commonly applied in software?
There is a theoretical bound on the discretization error (the difference bewtween the actual solution and the numerical solution).
If you can't solve the resulting algebraic system exactly, then this will be a further source of error. You can estimate this using Taylor's Theorem: if you are attempting to solve f(x) = 0 and the actual solution is x_{c}, then for the approximation x_n you have |f(x_n)| \approx |f'(x_n)||x_n - x_{c}| so that |x_n - x_{c}| \approx |f(x_n)|/|f'(x_n)|. You can then continue your iteration until this error is less than the theoretical maximum discretization error.
You have to distinguish between the solution of the discrete equations u_d and the exact solution of the continuous equations u.
When using an iterative solver, you start with an estimate of u_d and you update this estimate at every iteration, let's call this u_d^{i}. So at every iteration, you compute a new estimate of your discrete solution, and the error is e_d = |u_d^{i} - u_d|. The residual is what you get when you substitute your current estimate u_d^{i} into your discretized PDE. If your numerical method converges, your residual goes to zero. The error and the residual are related: |e| < C\cdot|R|, and a lot of study has gone into getting accurate estimates of this constant C. So when the residual is zero, you can be pretty sure that you have found the solution of the discretized PDE (within machine precision). What remains is the error e = |u_d - u|. In general, you do not know this error, although we do know that the error goes to zero when the mesh element size goes to zero, and we also know that the rate of convergence is equal to the order of the numerical method. What you can do is compute a second solution on a finer mesh and compare this to the first solution.
You now have 2 solutions, one on the coarse mesh 1: u_{d_1} on the fine mesh 2: u_{d_2}. An important observation is that if you interpolate the solution of mesh 1 (with residual R=0) to the finer mesh 2 and recompute the residual, the residual on the new mesh is not zero anymore.
If you have 3 meshes with 3 solutions, you can use Richardson extrapolation to get an estimate of the error.
Likes feynman1
What drives the iterations? Changing mesh size to check for convergence?
thanks a lot and I wonder what could be the reason if |u-ud| doesn't decrease with refined meshes? If the true solution of the PDEs is of a highly oscillatory nature in space, would the residual of the PDEs (containing spatial derivatives) be hard to be suppressed?
if the solution is time dependent, then you have to converge the residuals every time step. If the residuals do not go down anymore, this is usually because for practical problems, you have a complicated geometry with an unstructured mesh, and the cells are not perfect squares or triangles.
Likes feynman1
what if the residual of the discrete system yielding the ud solution goes down with iterations but f(ud) doesn't (f defined in #4 so f(uex)=0 where uex is exact)?
how is the "residual of the discrete system yielding u_d" different from f(u_d)=R?
I'm not sure. f is some differential operator and it takes derivatives, whereas the discrete system has no derivative. Would the gibbs phenomenon make the discrete solution so bad on highly oscillatory regions that the residual will never be small?
how large is the residual of a discrete solution of a PDE from 0 in order of magnitude?
  • · Replies 65 ·
