Resonance Propulsion: Using EM Waves to Induce Movement
  • Context: Graduate
  • Thread starter Thread starter Human268
    Propulsion Resonance
The discussion centers on the concept of resonance propulsion, where solid materials possess a mechanical resonance frequency that can be modified. The proposed method involves energizing the material through mechanical vibration and then applying pulsed electromagnetic (EM) waves at frequencies that correspond to the material's bond energies. This technique aims to induce propulsion by striking the material in phase with its mechanical resonance frequency, potentially allowing for movement similar to radiation pressure effects.
  • Understanding of mechanical resonance frequency in solid materials
  • Knowledge of electromagnetic wave properties and frequencies
  • Familiarity with oscillation mechanics and conservation of momentum
  • Basic principles of propulsion and force emission
  • Research the principles of mechanical resonance in materials
  • Explore the interaction between electromagnetic waves and solid materials
  • Study the effects of radiation pressure on propulsion systems
  • Investigate practical applications of resonance propulsion in engineering
Researchers in materials science, physicists exploring propulsion technologies, and engineers interested in innovative propulsion methods will benefit from this discussion.
Human268
Here's a weird idea: solid materials each have an inherent, but potentially modifiable mechanical resonance frequency. Step 1- energize the material mechanically by inducing vibration (ie. increasing the amplitude of occillations). Step 2- strike the material intermittently with an intense and pulsed electromagnetic waves (EM frequencies corresponding to bond energies within the material so that it can induce mechanical movement), pulsed "in phase" at the mechanical resonance frequency of the material inducing propulsion.
Any thoughts?
Any thoughts?
and how do you think any sort of propulsion is achieved ?
consider what is occurring in an oscillationDave
theoretically you would pulse the EM wave to be "in phase" with the oscillations, striking the molecular bonds at the moment during the oscillation when the material is moving away from the EM wave. This, in theory, would move the entire oscillating material forward.
I don't see any reason to think this would work any differently than the force exerted by radiation pressure.
you're probably right. But I wonder if there is a way to use mechanical resonance of materials to induce propulsion.
You have to emit something to get propulsion (or change the velocity of something coming from the outside). This is just conservation of momentum. So what do you want to emit?
Most likely there would be an equal and opposite force on whatever was emitting the EM.
  • · Replies 21 ·
  • · Replies 16 ·
9K
  • · Replies 264 ·
32K
