Rewriting complex number expressions
The discussion revolves around rewriting complex number expressions in the context of electrical engineering, specifically involving a single-phase mill affected by a resistive load. The original poster presents a voltage expression over a capacitor in terms of complex phasors and seeks to express it in a standard cosine form.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to rewrite the voltage expression by manipulating the exponential form and extracting the real part. Some participants question the correctness of the multiplication process with complex numbers and suggest using the conjugate for simplification.
  • There is a discussion about the need to simplify the resulting expression and the challenges faced in rewriting it to the desired cosine form.
  • Participants explore the use of trigonometric identities to aid in the transformation of the expression and raise questions about how to define amplitude and phase angle.
Participants are actively engaged in clarifying the steps needed to rewrite the expression correctly. Some have provided guidance on using trigonometric identities and equating coefficients to find the amplitude and phase angle, while others express uncertainty about the process and seek further clarification.
There is an acknowledgment of missing definitions for certain parameters, such as amplitude, and the discussion includes references to specific mathematical identities that may be relevant to the problem-solving process.
Tyrone123
The mill (single phased) is now affected by a load from a resistor. We assume that the turbine can deliver an infinitely large current without affecting the frequency.
figure 1 illustrates the load:
http://puu.sh/19GGR
The voltage over the capacitor can can be expressed as
V0(t) = Re(vp * ei*ω*t)
where ω is the angular frequency, i is the complex number, and vp is a complex number (also called a phasor) and can be expressed as
vp = k * [itex]\frac{1}{1+iω*R*C}[/itex]
The values R and Ck er unknown, but can be assumed to be constant and real.
Make an expression for V0(t) where only the real part is described.
Rewrite the expression for V0(t) to the form V0(t) = A * cos(ωω*t + θω)
Where A is the amplitude
As for the first part, my idea was to rewrite the exponential part ei*ω*t to cos(t*ω)+i*sin(t*ω) and then multiply it with vp as you would with two complex numbers, and then simply discard the imaginary part..
which gives me [itex]\frac{k*cos(t*w)}{1+w*R*C}[/itex]
But I am pretty sure I am way off.. and I could use some help!
I don't think you are doing the 'multiply by v_p' part correctly. If you have a complex number in the denominator and you want to take the real part you need to multiply numerator and denominator by the conjugate of the denominator. For example, 1/(a+bi)=(a-bi)/((a+bi)(a-bi))=(a-bi)/(a^2+b^2). Show the details of how you got your answer.
I realize my mistake and I have now ended up with the following equation for vp by multiplying both the denominator and numerator by the conjugate of the denominator
http://puu.sh/19J1F (having issues with the fraction feature, so excuse me pasting an image instead)
the above expression for vp is then multiplied with ei*w*t (which equals cos(t*w)+ i*sin(t*w).. which leaves me with one hell of result, but as I am supposed to find the real part of the expression, I can simply discard the imaginary part of the result from the multiplication at this point?
if so, I end up with this expression for the real part of the complex number:
http://puu.sh/19J7t
which still isn't very pretty.. if this was the correct procedure, any thoughts on how to simplify it?
http://puu.sh/19J7t
That looks right. It doesn't get too much simpler than that, you could write it over the common denominator, but that's not a whole lot simpler.
If we can agree that http://puu.sh/19J7t is the result to the first part, namely finding an expression for the real part of the equation v_p * ei*w*t.. then so far so good.
The next part, which is to rewrite that expression to the form
I am very unsure of how to proceed.. there is no given definition of A (which is the amplitude).. my teacher mentioned something about using trigonometric identities such as cos(x - y) = cos(x) cos(y) + sin(x) sin(y) to help rewrite it.. but I can't seem to grasp his idea..
Just expand that expression for V0(t) using that trig identity and equate it to the real part that you found. The coefficients of cos(wt) and sin(wt) must be the same on both sides. Try to solve for A and θ. To get a notion of what the result should look like there is a similar formula in http://en.wikipedia.org/wiki/List_of_trigonometric_identities under 'Linear combinations'.
"just" :3
Expanding the desired expression with the trig identity I mentioned equals
V0(t) = A * (cos(w*t) * cos(θ) - sin(w*t) * sin(θ))
and equating it to http://puu.sh/19J7t where the coefficient of cos(t*w) is [itex]\frac{k}{(W^2 *R^2 *C^2) }[/itex]
and the coefficient of sin(t*w) is [itex]\frac{w*R*C*k}{W^2 *R^2 *C^2)}[/itex]
from here I am not sure how to approach it.. since the coefficient on the left side is just A, but on the right side its different for cosine and sinus.
you said "solve for A and θ".. by that do you mean to take the two equations, equate them and isolate A from that? (and same for θ)
I mean that the two equations you then want to solve are [tex]A cos(\theta)=\frac{k}{W^2 R^2 C^2}[/tex] and [tex]-A sin(\theta)=\frac{w R C k}{W^2 R^2 C^2}[/tex] for [itex]A[/itex] and [itex]\theta[/itex]. It's not as hard it might look. First square both equations and add them and see if you can find [itex]A[/itex]. Then divide the two equations and see if you can solve for [itex]\theta[/itex].
  • · Replies 22 ·
  • · Replies 28 ·
