Riemann Curvature Tensor Symmetries Proof
The discussion focuses on the proof that the expression $$\varepsilon^{abcd} R_{abcd}$$ equals zero by utilizing the symmetries and antisymmetries of the Riemann curvature tensor, specifically the identities: symmetry $$R_{abcd} = R_{cdab}$$, antisymmetry for the first pair of indices $$R_{abcd} = - R_{bacd}$$, antisymmetry for the last pair of indices $$R_{abcd} = - R_{abdc}$$, and the cyclic property $$R_{abcd} + R_{adbc} + R_{acdb} = 0$$. The conclusion drawn is that after applying these identities, the terms cancel out, leading to the result $$\varepsilon^{abcd} R_{abcd} = 0$$. The discussion also clarifies the properties of the Levi Civita symbol and its relationship with the Riemann tensor.
  • Understanding of Riemann curvature tensor properties
  • Familiarity with Levi Civita symbol and its symmetries
  • Knowledge of tensor algebra and index notation
  • Basic concepts of general relativity
  • Study the properties of the Levi Civita symbol in detail
  • Learn about the implications of Riemann curvature tensor symmetries in general relativity
  • Explore advanced tensor calculus techniques for manipulating tensor expressions
  • Investigate applications of the Riemann curvature tensor in differential geometry
Mathematicians, physicists, and students of general relativity who are interested in the properties of curvature tensors and their applications in theoretical physics.
Emil
I am trying to expand $$\varepsilon^{{abcd}} R_{{abcd}}$$ by using four identities of the Riemann curvature tensor:
Symmetry
$$R_{{abcd}} = R_{{cdab}}$$
Antisymmetry first pair of indicies
$$R_{{abcd}} = - R_{{bacd}}$$
Antisymmetry last pair of indicies
$$R_{{abcd}} = - R_{{abdc}}$$
Cyclicity
$$R_{{abcd}} + R_{{adbc}} + R_{{acdb}} = 0$$
From what I understand, the terms should cancel out and I should end up with is $$\varepsilon^{{abcd}}R_{{abcd}} = 0$$. What I ended up with was this mess:
$$\begin{array}{l}
\varepsilon^{{abcd}} R_{{abcd}} = R_{\left[ {abcd} \right]} =
\frac{1}{4!} \left( \underset{- R_{{dcab}}}{\underset{+
R_{{cdab}}}{\underset{- R_{{abdc}}}{\underset{{\color{dark green}
+ R_{{badc}}}}{\underset{- {\color{red} {\color{black}
R_{{bacd}}}}}{{\color{blue} R_{{abcd}}}}}}}} +
\underset{{\color{magenta} - R_{{adbc}}}}{\underset{{\color{red} +
R_{{cbad}}}}{\underset{- R_{{cbda}}}{\underset{+
R_{{bcda}}}{{\color{magenta} {\color{black} R_{{dabc}}}}}}}} +
\underset{- R_{{abdc}}}{\underset{+ R_{{dcba}}}{\underset{-
R_{{cdba}}}{\underset{- R_{{dcab}}}{\underset{{\color{dark green}
+ R_{{badc}}}}{\underset{- R_{{bacd}}}{\underset{+
R_{{abcd}}}{R_{{cdab}}}}}}}}} + \underset{+
R_{{dabc}}}{\underset{- R_{{cbda}}}{\underset{{\color{red} +
R_{{cbad}}}}{\underset{- {\color{blue} {\color{black}
R_{{bcad}}}}}{{R_{{bcda}}}}}}} - \underset{-
R_{{bdca}}}{\underset{{\color{blue} + R_{{acdb}}}}{\underset{+
R_{{dbca}}}{\underset{- R_{{dbac}}}{\underset{+
R_{{bdac}}}{R_{{acbd}}}}}}} - \underset{{\color{blue} +
R_{{adbc}}}}{\underset{- R_{{bcda}}}{\underset{+ {\color{blue}
{\color{black} R_{{bcad}}}}_{}}{\underset{{\color{red} -
R_{{cbad}}}}{R_{{adcb}}}}}} - \underset{{\color{black} +
R_{{abcd}}}}{\underset{- R_{{bacd}}}{\underset{{\color{dark green}
+ R_{{badc}}}}{R_{{abdc}}}}} - \underset{{\color{magenta} +
R_{{abcd}}}}{\underset{- R_{{abdc}}}{\underset{{\color{red}
{\color{dark green} + R_{{badc}}}}}{\underset{- {\color{red}
{\color{black} R_{{bacd}}}}}{R_{{cdba}}}}}} \right)
\end{array}$$
where I can get rid of the blue or the purple terms using cyclicity (sorry for colors but it'll be a pain to change it), but I'm stuck because I can't see how I can get all the terms to cancel. The main problem seems to be is that the last term in the cyclicity identity $$\left(R_{{acdb}} \right)$$ can only be acquired from the 5th term $$\left(R_{{acbd}} \right)$$ in the expression i have. After I get rid of 6 terms with cyclicity I was thinking I could get of what remains with some symmetry relationship. Am I going down the wrong path here? Do I need another relationship? Carroll in ``Introduction to General Relativity'' says in eq 3.83 that all I have to do is expand the expression for $$R_{\left[ {abcd}\right]}$$ and mess with the indicies using the 4 identities to proove that it reduces to zero. Thank you for any help.
Let's see:
\epsilon^{abcd} R_{abcd}
By using the symmetries and antisymmetries you won't get anything, because both R and E have the same identities.
\epsilon^{abcd} = - \epsilon^{bacd}
\epsilon^{abcd} = - \epsilon^{abdc}
\epsilon^{abcd} = \epsilon^{cdab}
So you might have to use the cycling identity:
R_{abcd} = - R_{adbc} - R_{acdb}
then look at the contraction:
LHS: \epsilon^{abcd} R_{abcd}
RHS:
-\epsilon^{abcd} R_{adbc}= -\epsilon^{adbc}R_{adbc} \equiv -\epsilon^{abcd}R_{abcd}
whereas the second term:
-\epsilon^{abcd} R_{acdb}= - \epsilon^{acdb}R_{acdb} \equiv -\epsilon^{abcd} R_{abcd}
explain steps: In the first = I have used the symmetries of epsilon.. in the equivelant step I just renamed the summed indices.
So you have:
\epsilon^{abcd} R_{abcd} = - 2 \epsilon^{abcd}R_{abcd}
so it must be zero?
I hope this helps...Sorry but I don't understand what matrix is the one you have written...
Thank you for the quick reply!
I'm having trouble understanding the first = sign. How you got from
$$\varepsilon^{abcd} \overset{\left( i i \right)}{\longrightarrow} -
\varepsilon^{abdc} \longrightarrow ? \longrightarrow
\varepsilon^{adbc}$$ As far as I can see from the three identitites you
can't switch d and b like that. The identities allow either switching the
first pair of indicies with the second pair (iii) then
(i) and (ii) allow switching the two indicies
in the first OR the second pair, respectively. I understand the idea of
renaming the indicies in the equivalence sign you did afterwards.
$$ (i) \varepsilon^{{abcd}} = - \varepsilon^{{bacd}}$$
$$ (ii) \varepsilon^{{abcd}} = - \varepsilon^{{abdc}}$$
$$ (iii) \varepsilon^{{abcd}} = \varepsilon^{{cdab}}$$
the epsilon is the Levi Civita symbol... it's symmetric under even permutations of its indices and antisymmetric under odd permutations of its indices. Or put in other words, it's a totally antisymmetric thing...that's not the case for R, which is an antisymmetric tensor to its first 2 and last 2 indices and symmetric under the interchange of them two...
The (i),(ii),(iii) you write and which I referred to is just an illustration of this property and I referred to them because I wanted to tell you that you can't eventually use that to show eg symmmetric \times antisymmetric =0, but you had to use the cyclic property of R to work it out.
i: is an odd permutation of indices (odd=1) a,b
ii: is again an odd permutation of indices c,d
iii: is even (4) permutation of indices:
\epsilon^{abcd}= -\epsilon^{acbd} = \epsilon^{acdb}= - \epsilon^{cadb} =\epsilon^{cdab}
So \epsilon^{abcd}= \epsilon^{cdab}
Great! I was getting the Levi Civita properties confused with the Riemann Tensor's properties. Thanks again I think I got it.
^editted.
