Robotics Kit for Beginners: $1,000 Budget
For a $1,000 budget, several entry-level robotics kits are recommended, including LEGO® MINDSTORMS® NXT 2.0 priced at $279.99, which offers essential components and programming capabilities. The discussion also highlights resources like Arduino and MakerBot for customizable projects. While a complete kit for $1,000 may be challenging to find, investing in used parts could provide extensive building opportunities. The conversation emphasizes the importance of starting with manageable complexity for beginners. Overall, these suggestions aim to facilitate a solid foundation in robotics for newcomers.
apc3161
Hello all,
I was wondering if any of you knew of a really good entry level robotics kit and where I could get one. My budget is probably around $1,000.
I'm looking for a kit that has all the essential components, a computer interface, customizable programming etc.
I don't know much about robotics (I just have a bachelors in mech. eng), so I want to start from scratch, put it together myself, program it etc.
Obviously though, since this is my first attempt, it shouldn't be too complicated. If anyone knows of a good place to start I would appreciate it. Thanks
see for starters
Price USD 279.99
Item #: 8547
(open source)
http://www.arduino.cc/
http://store.makerbot.com/makerbot-thing-o-matic.html
all these I have used or am using.
An entry level kit for $1000?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
24K
