Roots of -8: Solving with Exponential Form
  • Thread starter Thread starter 31415
    Roots
8 replies · 2K views
31415
I'm supposed to find the 6 roots of -8 + 0i
we are told the usual method of for these problems is to put the complex number into it's exponential form like so
z = |z|exp( i(θ+2πk)) where k: [0 to n-1]
then put it to the relevant power 'n'
z1/n = |z|1/nexp(( i(θ+2πk)/n)
so I proceed by taking θ to be pi...
z1/6 = 81/6exp(( i(π+2πk)/6)
thinking the question is easy...
then in the solution given for the question the answer is 81/6exp(( i(-π+2πk)/6)
I don't understand where this minus has come from - is the solution wrong or am I missing something?
(picture of question and solution attached)
Both expressions are the same 6 numbers, it's just that the value of k in one set is shifted by 1 with respect to the other set.
You could always use
w_k = r^{1/n}\left[\cos\frac{\theta + 2\pi k}{n}+i\sin\frac{\theta + 2\pi k}{n}\right]
where ##n## is the number of roots in your case 6, ##\theta## is the angle, and ##k = 0,1,..,n-1##
Then ##r = 8## and ##\theta = \pi## where the principle argument is define as ##\theta\in (-\pi,\pi]##
So
w_k = 8^{1/6}\left[\cos\frac{\pi + 2\pi k}{6}+i\sin\frac{\pi + 2\pi k}{6}\right] = 8^{1/6}\exp\left[i\frac{\pi + 2\pi k}{6}\right]
So how could ##\pi## be negative? Simply define the the principle argument to be ##\theta\in [-\pi,\pi)##.
And sometimes it will be defined be excluding ##\pi## all together like ##\theta\in (-\pi,\pi)##
ah i see when I take the principle arguments of each root then the answers agree - thanks all. Still don't understand why he decided to do it like that but I guess it doesn't matter :)
SammyS said:
You're supposed to find the 6 sixth roots of -8 .
yeah I know that - ... e^i*pi = -1
8 e^i*pi = -8
e^2*pi*k =1 for k: 0,1,2,3...
And of course you can write ##\sqrt{2}## in place of ##8^{1/6}## in your answer.
