Rotational spectrum - equidistance
  • Level: Graduate
  • Thread starter Thread starter Petar Mali
    Rotational Spectrum
4 replies · 3K views · last reply
Petar Mali
Difference between two rotational terms is given by
[tex]\tilde{\nu}=(J+1)(J+2)B-J(J+1)B=2B(J+1)[/tex]
If we put values of [tex]J[/tex] in this expression we get that otational spectrum is equidistant.
[tex]T_r[/tex] - rotational term
[tex]J[/tex] - rotational quantum number
But from this picture spectrum isn't equidistant.
http://www.mwit.ac.th/~physicslab/hbase/molecule/imgmol/rotlev.gif
Can you tell me where is the problem? Thanks!
I can't view the picture. But the equation you cite is valid for the rigid rotor approximation. Real systems tend not to act like that except for low rotation numbers.
I put the other picture
http://www.mwit.ac.th/~physicslab/hb...mol/rotlev.gif
Look at this picture. You have rotation and vibration levels. Yes I assume that two moleculs system - rigid rotor approximation.
Right well what's the question? Why the approximation fails at higher rotational states?
Simply "centrifugal force" - the interatomic distance increases at higher rotation speeds/states, you get a different B.
The centrifugal force is not the case in this picture
[tex]E_r=J(J+1)\frac{\hbar^2}{2I}[/tex]
[tex]T_r=\frac{E_r}{hc}[/tex]
For [tex]J=0[/tex] [tex]T_r=0[/tex]
For [tex]J=1[/tex] [tex]T_r=2B[/tex]
For [tex]J=2[/tex] [tex]T_r=6B[/tex]
For [tex]J=3[/tex] [tex]T_r=12B[/tex]
It isn't equidistant if I calculate like this. And in picture which you see is this terms. It looks like contradiction if you look this post and my first post!
