Satellite orbiting Earth angular velocity and frequency calculation
5 replies · 1K views · last reply
Safinaz
A satellite orbits the Earth at a speed of 3100 m/s in an orbit that passes through the north and south points and has a radius of ##4.2 \times10^7## m. Consider a point moving in a straight line along the north-south axis of the Earth and passing through its center such that its speed is always equal to the component of the satellite's velocity in the north-south direction. Find a) the frequency of the point's motion, b) the acceleration of the point at the two end points of the motion, and c) its maximum speed.
The angular frequency : ## \omega= \frac{v}{x}##
The frequency ## f= 2 \pi \omega ##
For a SHM: ## a = - \omega^2 x##
The maximum velocity: ## v = - v_{max} sin ( 2 \pi f t ) ##
I tried to solve by calculating:
## \omega = \frac{v}{x} = 3100/ (4.2 \times10^7) ##,
Which makes the frequency so small:
## f = 2 \pi \times 3100/ (4.2 \times10^7) \sim 10^{-5} ~ s^{-1} ##
And also the acceleration and velocity. So I think there is a mistake in my solution.
Any help to solve this problem accurately is appreciated.
You could look up the altitude for geosynchronous orbit and compare that to ##4.2 \times 10^7## meters.
What is the frequency for geosynchronous orbit?
Check the units: radians/cycle x radians/second =?
What does that make the orbital period to be? Is that unreasonable?
While OP has written down the wrong formula, their numerical result corresponds to the correct one.
Here is another reality check for your solution. Why do you think your acceleration is small? What do you expect it to be at a radius of 42000 km given that it is about 10 m/s^2 at the Earth radius 6700 km?
