Schwarzschild in Cartesian: Tricks for Transformation
The forum discussion centers on the transformation of the Schwarzschild metric from spherical to Cartesian coordinates, specifically addressing the discrepancies encountered when applying the transformation. The participants clarify that the radial coordinate R, defined as R = (x² + y² + z²)^(1/2), is not equivalent to the areal radius r, leading to confusion in the transformation process. The correct approach involves recognizing the relationship between r and R, particularly when deriving isotropic coordinates, which simplifies the Schwarzschild metric for large r.
  • Understanding of General Relativity and the Schwarzschild metric
  • Familiarity with coordinate transformations in differential geometry
  • Knowledge of isotropic coordinates and their significance in gravitational fields
  • Basic proficiency in mathematical notation and differential equations
  • Study the derivation of isotropic coordinates from the Schwarzschild metric
  • Learn about the implications of coordinate transformations in General Relativity
  • Explore the concept of the areal radius and its relationship to Cartesian coordinates
  • Investigate the linearized form of the Schwarzschild metric and its applications
Students and researchers in theoretical physics, particularly those focusing on General Relativity, gravitational theory, and mathematical physics, will benefit from this discussion.
epovo
TL;DR
What is the appropriate coordinate change?
According to Schutz, the line element for large r in Schwarzschild is
$$ ds^2 \approx - ( 1 - \frac {2M} {r}) dt^2 + (1 + \frac {2M} {r}) dr^2 + r^2 d\Omega^2 $$
and one can find coordinates (x, y, z) such that this becomes
$$ ds^2 \approx - ( 1 - \frac {2M} {R}) dt^2 + (1 + \frac {2M} {R}) (dx^2+dy^2+dz^2) $$
where ## R \equiv (x^2 + y^2 + z^2)^{1/2} ##
This makes sense, as it is the same as the weak field metric with ## \phi = -M/r ## (Newtonian gravitational field).
However, if I try to go from the first to the second using the usual spherical to Cartesian transformation, I get something different. Am I missing a trick here?
I recall I had this same confusion when I was learning GR!
Why by the pendulous yarbles of Zeus would you want to take a system with spherical symmetry and work it in rectangular coordinates?
I don't have any special interest, I was just following Schutz and intrigued by his phrasing "One can find coordinates in which..." rather than the more natural "In Cartesian we have...". So just applied the transformation and I got an extra term that refuses to go away:
$$ ds^2 \approx - ( 1 - \frac {2M} {R}) dt^2 + (1 + \frac {2M} {R}) (dx^2+dy^2+dz^2) -2RM d\Omega^2 $$
I think the problem is that ##r \ne R##. You need to take ##R## as some function of ##r##. This will be buried in my notes somewhere.
Well, Schutz says explicitly that ## R \equiv (x^2 + y^2 + z^2)^{1/2} ##
First, all that means is what it says. That the metric involves coordinates ##t, x, y, z## with ##R## defined as above to simplify the terms in the denominators.
Second, there is no sense in which ##r^2 = x^2 + y^2 + z^2##.
But I thought ## r^2 = x^2 + y^2 + z^2 ## is part of the coordinate transformation! :frown:
That was your chosen coordinate transformation. It was the wrong one. Which is what I'm trying to point out!
I see! But then, which is the right one, that would give me the result I am after???
That's the question. What I would do is look at ##x, y, z## with their usual spherical definitions and compare them to ##r## and ##R##. I think that's how I figured it out.
Thank you for the tip. I will try some more
A fair question, but in this case probably to linearise the scwarzschild metric (taking only first order in 2M/r) to identify the components of the linearised metric, ##h_{00}## = 2##\phi##/##c^2## and ##h_{ij}## = 2##\phi## ##\delta_{ij}##/##c^2##. (As opposed to doing it by solving the linearised field equations).
Note that you still have x, y and z's buried in the Ω.
No. ##R = x^2 + y^2 + z^2## is part of the coordinate transformation. But ##R## (capital R) is not the same as ##r## (lower case r). The latter is the "areal radius", i.e., ##r = \sqrt{A / 4 \pi}##, where ##A## is the surface area of a 2-sphere at ##r##. In flat spacetime, we would indeed have that ##r = R##; but you are not asking about flat spacetime.
Let's do the transformation explicitly. We start with the usual "Schwarzschild coordinates":
$$\mathrm{d} s^2=\left (1-\frac{2m}{r} \right) \mathrm{d} t^2 -\frac{1}{1-2m/r)} \mathrm{d} r^2 + r^2 \underbrace{(\mathrm{d} \vartheta^2 + \sin^2 \vartheta \mathrm{d} \varphi^2)}_{\mathrm{d} \Omega^2},$$
where ##m=GM/c^2=r_{\text{S}}/2##.We want to introduce a new radial coordinate, ##R##, such that the spatial part is
$$\propto \mathrm{d} \vec{x}^2 = \mathrm{d} R^2 + R^2 (\mathrm{d} \vartheta^2 + \sin^2 \vartheta \mathrm{d} \varphi^2).$$
The spatial part of the line element is
$$\mathrm{d} \sigma^2 = \frac{1}{1-2m/r} \mathrm{d} r^2 + r^2 \mathrm{d}\Omega^2 = \frac{1}{2-2m/r} r^{\prime 2} \mathrm{d} R^2 + \frac{r^2}{R^2} R^2 \mathrm{d} \Omega^2.$$
The prime denotes the derivative wrt. the new radial coordinate, ##R##.
To get "isotropic coordinates" we thus want
$$\frac{r^{\prime 2}}{1-2m/r} = \frac{r^2}{R^2}.$$
This ODE is easily solved by separation, leading to [EDIT: Corrected typo, the factor of 2 on the left-hand side in view of #18]
$$\frac{2R}{m} =\frac{r-m}{m} + \sqrt{\frac{r(r-2m)}{m^2}}$$
or
$$r=R [1+m/(2R)]^2.$$
Plugging all this into the line element indeed leads to what's given in Wikipedia
$$\mathrm{d} s^2 = \left (\frac{1-m/(2R)}{1+m/(2R)} \right )^2 \mathrm{d} t^2 - [1-m/(2R)]^4 (\mathrm{d} R^2 +R^2 \mathrm{d} \vartheta^2 + R^2 \sin^2 \vartheta \mathrm{d} \varphi^2],$$
i.e., introducing the usual "Cartesian coordinates"
$$\vec{x}=R \begin{pmatrix}\cos \varphi \sin \vartheta \\ \sin \varphi \sin \vartheta \\ \cos \vartheta \end{pmatrix},$$
i.e.,
$$\mathrm{d} s^2= \left (\frac{1-m/(2R)}{1+m/(2R)} \right )^2 \mathrm{d} t^2 - [1-m/(2R)]^4 \mathrm{d} \vec{x}^2.$$
Note that the Schwarzschild Radius is ##r_S=2m##.
The advantage of these coordinates is the same advantage that have Cartesian coordinates over spherical coordinates, i.e., the invariance under the full rotation group ##\vec{x} \rightarrow \hat{R} \vec{x}## with ##\hat{R} \in \mathrm{SO}(3)## is manifest, while in spherical coordinates it's not, because you distinguish the polar axis as a "preferred direction".
$$\frac{R}{m} =\frac{r-m}{m} + \sqrt{\frac{r(r-2m)}{m^2}}$$
or
i.e.,
Thank you, @vanhees71.
I would have never figured this out myself.
I have followed your derivation and only found that the initial conditions of the ODE demand a factor of 2 here:
$$ 2\frac{R}{m} =\frac{r-m}{m} + \sqrt{\frac{r(r-2m)}{m^2}}$$
That is from demanding that for large r, ##R \approx r ##
otherwise it doesn't work.
You are right. That was a typo. I'll correct it in the OP.
  • · Replies 50 ·
  • · Replies 43 ·
