Searching for compressive stress of silica aerogels
The discussion centers on the compressive stress of silica aerogels, specifically referencing the work of Dylan J. Boday regarding cyanoacrylate reinforcement. It is established that compressive strength cannot be directly derived from three-point bending tests, as these tests measure tensile strength and are influenced by surface defects. The compressive strength of cyanoacrylate reinforced silica aerogel is approximated at 166,084 Pa at a density of 0.22 g/cm³ under specific conditions, indicating that this material is significantly weaker than anticipated.
  • Understanding of mechanical properties of materials
  • Familiarity with three-point bending tests
  • Knowledge of compressive strength measurement techniques
  • Basic concepts of aerogel composition and reinforcement methods
  • Research "mechanical properties of aerogels" for comprehensive understanding
  • Investigate "compressive strength testing methods" for accurate measurement techniques
  • Explore "cyanoacrylate reinforcement in composites" for material enhancement strategies
  • Look into "aerogel density and strength charts" for comparative analysis
Material scientists, engineers, and researchers focused on aerogel properties and applications, particularly those interested in mechanical strength and reinforcement techniques.
lavalite
I have no formal training in any type of engineering, so if my request is confusing, I apologize.
I believe I am seeking data on the ultimate internal stress of various silica aerogels in compression mode.
I found a paper published by Dylan J. Boday where CVD of cyanoacrylates was used to reinforce the aerogels (1). A three-point compression analysis and rupture strength is discussed, but not internal stress. Is it possible to calculate the internal stress from the listed rupture strengths?
(1) Boday, D. et al.; chemistry of materials, 2008, 2009, 2847
You apparently want to find the compressive strength of various silica aerogels from the three point bending strength in that paper. Not possible, because they are measured differently and measure different properties.
The specimen in a three point bending test typically fails in tension, in which case the test measures the tensile strength in the presence of surface defects. Compressive tests are normally not sensitive to surface defects, so compressive strength can be greater than the result of a three point bending test. This is material dependent. Steel, for example, has compressive strength close to tensile strength, while concrete has tensile strength about 8% of compressive strength.
Good search terms to learn more are mechanical properties aerogel.
Ok thanks a lot, I appreciate your reply and help.
I have attempted to use the search term that you suggested but I'm still having difficulty finding the information that I'm trying to find. I really wish I could find a chart that had information like type, density, and compressive strength. Does anybody know where I can find charts that have that information?
I'll check that out, thanks for the link Tom!
WARNING: Assumptions and approximations ahead!
The compressive strength at failure of cyanoacrylate reinforced composite silica aerogel (1) may be as high as 166,084pa at a density of 0.22g/cm^3 if;
  • The sample can support 3200 times its own weight in true compression.
  • The sample is cylindrical.
  • The sample is twice as tall as its diameter.
  • The sample is 2.3 times its unreinforced mass of 0.262g.
Sadly, if this approximation is even close to correct, then this material is 60 times weaker than I'd hoped for it to be. I guess it's back to the drawing board.
(1) Boday D.J.; et al Applied Materials & Interfaces, 2009, 1365-1366
  • · Replies 19 ·
