Second Shift Theorem: Integral Explanation
8 replies · 3K views · last reply
goldfish9776
for the alternative form of second shift property (4.8) , why he integral of (e^-sp) g(p+a) dp isn't equal to integral of (e^-sp) g(t) dp ? why it will become L{ g(t+a) } ?
  • Boxed Theorem 4.8 (Second Shift Property) with proof: Laplace transform of f(t-a)H(t-a) equals e^(-as) times F(s), split into integrals from 0 to a and from a to infinity.
  • Handwritten derivation of the second shift theorem: integral from a to infinity of e^(-s(p+a)) f(p) dp after substituting p = t - a, then e^(-as) times the integral from 0 to infinity of e^(-sp) f(p) dp, then e^(-as) L{f(t)}, hence L{f(t-a)H(t-a)} = e^(-as) F(s).
  • Handwritten derivation of the alternative form of the second shift theorem, rotated 180 degrees, with Laplace transform steps and substitutions shown in equations (4.8) and (4.28).
Would you mind showing more work explaining your reasoning?
I imagine the answer is either in the endpoints of your integrals or the substitution.
Straight off, from your question, for ##t = p+a##
##\int e^{-sp}g(p+a) dp = \int e^{-sp}g(t) dp##
but you can't do much with that...complete the substitution to change the whole integral into one with only dependence on t and no p's.
ya , why not the final ans not L {g(p+a)} ?
Write out the steps with the limits of integration. Do the substitutions where appropriate to make sure the new integrals are from zero to infinity.
is my working until here correct ?
  • Handwritten integration by parts working on lined paper: integral from 0 to infinity of e^(-sp) g(p+a) dp, rewritten as integral of e^(-sp)(gp+ga)dp, with u = e^(-sp), dv/dx = gp+ga, and integration by parts boundary terms and a further integral shown below.
It looks like you are treating g(p+a) as a multiplication. g(x) is a function.
Also, when you do substitutions within integrals, you have to change the limits as well.
For example:
Substituting ##t = p+a\quad p = t-a\quad p=0 \implies t = a##
##\int_0^\infty e^{-sp}g(p+a) dp = \int_{a}^\infty e^{-s(t-a)}g(t) dt##
Does that make sense?
For example:
i gt stucked here , how to continue?
  • Handwritten integration by parts on a Laplace transform: integral from a to infinity of e^(-s(t-a)) g(t) dt, rewritten as e^(sa) times the integral of e^(-st) g(t) dt, with u = g(t), v' = e^(-st), v = -e^(-st)/s.
You are looking to show that ##\mathcal{L}\{ g(t) \mathcal{H}(t-a) \} = e^{-as}\mathcal{L}\{ g(t+a)\}.##
Start by expanding the transform:
##\mathcal{L}\{ g(t) \mathcal{H}(t-a) \} =\int_0^\infty e^{-st}g(t) \mathcal{H}(t-a)dt##
Apply the Heaviside function:
##\qquad \qquad =\int_a^\infty e^{-st}g(t) dt##
Because this integral does not start at 0, we need to shift it with a substitution.
Substitute t = p+a ... p = t-a ... dt = dp ...and where t = a, p = 0 (for the limits of integration).
##\qquad \qquad =\int_0^\infty e^{-s(p+a)}g(p+a) dp=\int_0^\infty e^{-sp-sa}g(p+a) dp##
Since a and s are not variables inside the integral, you can move them to the outside:
##\qquad \qquad =e^{-as} \int_0^\infty e^{-sp}g(p+a) dp.##
In this form you can see that this is the same as
## e^{-as}\mathcal{L}\{ g(p+a)\}## but since p could be any letter, you can name it t.
This will give you what you want to show:
Two things I noticed in your post #7...
1) There is no need to do integration by parts on this.
2) You did not distribute properly in your exponential: -s(t-a) = -st+sa.
