Semicircle Problem: What Does dA=R dR d(theta) Mean?
  • Context: Undergrad
  • Thread starter Thread starter n05tr4d4177u5
The discussion centers around the expression dA = R dR d(theta) in the context of calculating the area of a semicircle using polar coordinates. Participants explore the meaning of the notation and how to apply it to find the area, including the relationship between d(theta) and pi.
  • Homework-related
  • Some participants clarify that dA represents an area element in polar coordinates, suggesting that the inequalities for R and theta describe a specific region of a circle.
  • One participant attempts to relate the area element for a rectangle to that of a semicircle, questioning how to express dA in terms of known dimensions.
  • Another participant expresses confusion about integrating over a semicircle and seeks clarification on how to set up the integral correctly.
  • Some participants emphasize the importance of defining the coordinate system and the limits for R and theta when calculating the area of the semicircle.
  • There is a debate about the correct interpretation of theta's limits, with some asserting that theta should range from 0 to pi (not 180 degrees) for a semicircle.
  • Participants discuss the need to specify the function to integrate and the proper setup for the integral to compute the area.
Participants do not reach a consensus on the interpretation of the notation or the setup of the integral. There are competing views on how to approach the problem and differing opinions on the limits of integration.
Some participants express uncertainty about their mathematical skills and the integration process, indicating a potential gap in foundational knowledge that affects their ability to engage with the problem effectively.
This discussion may be of interest to students or individuals seeking to understand the application of polar coordinates in calculating areas, particularly in the context of semicircles and related geometric problems.
n05tr4d4177u5
i have been told that dA=R dR d(theta), what does mean exactly in terms of pi. the shape is a semicircle. Does this mean that d(theta) is 180, or pi. Please give me an example.
No, dA is a notation for an area element (infinitely small).
1. Suppose you are using polar coordinates r,\theta, what sort of region is described by the inequalities:
R\leq{r}\leq{R}+\bigtriangleup{R},\theta_{0}\leq\theta\leq\theta_{0}+\bigtriangleup{\theta}
You ought to see that this represent a specific portion of a section of a circle.
2. Now, if you let \bigtriangleup{R},\bigtriangleup\theta tend towards zero, you may approximate this region as a rectangle (or trapezoid, if you like that better). What should the (tiny!) area of this figure be?
that doesn't really help my question
here is an example of mine that i have
suppose i hae a rectangle,
in a rectangles case, dA = dX dY
if i have the rectangles width and it is 4 m, then dA = 4dY,
which let's me integrate along y axis,
now for a semicircle, how would i do that if dA = r dr d(theta)
also
so what i did, was changed dr to dy, and now i need to change d(theta) which should be a number (like in the case of 4 m for rectangle), and it has to be in terms of pi,
the shape is a semi circle
You do know how to integrate, don't you?
If you are to compute the area of the semicircle, the \theta integration is trivial, so you can find out that by yourself.
i don't know
no i don't know, its been a while since i integrated a circle
please help me, that's why I am asking, i haven't done that in years
Well, can you at least post the integral you want to compute, specifying the intervals in which R and the angle must lie in for the semi-circle?
y = d(theta) Y ^ 2
integrate from y=R to y= 0
Shape is semi circle
This is not what is in your book (it doesn't make any sense). Please type in correctly.
imagine the top half of a circle. the origin lies along the bottom of the semicircle, and in the middle. y-axis up, and x-axis to the right and left. i think theta can only go from 0 to 180 degrees since it is a semi circle. Y = d(theta) R squared
R = radius, integrate from 0 to R
What is Y?
Do you know what the d in front of (theta) means?
Well, why do you believe this to be true?
How do you derive that?
lol
are u reallly an advisor, cuase its unbelievable youve never seen that before,
example , the integral of ydy = y squared/ 2
Sure I have, but you are so vague and obtuse that I don't think you understand what you write yourself.
So, again:
show that you have at least a minimum of mathematical skill and understanding.
I have already shown you how you can do this problem, but it doesn't seem you have the competence to follow a perfectly clear line of reasoning.
You are good up to here.
Why can you write this? Where did it come from? You cannot just drop the dx and it is not automaticlly set to 4 or any other value.
One of the first things you need to do is carefully define your rectangle in terms of your coordinate system.
Suppose one corner is at the origin, x=y=0 and the diagonal corner is at x=L, y=W. To find the area we must define our integral:
\int dA = \int^{y=W}_{y=0} \int^{x=L}_{x=0} dx dy
Can you complete the above integral?
Ok, now let's set up the integral for the area of a semi circle.
Once again we need to define the circle in terms of the coordinate system.
If the center of the circle is at the origin and the radius is R.
So to get the Area of the circle (or portion there of) the radius will take on values between 0 and R, while the angle \Theta varies from 0 to \pi (for a semi circle). Now let's set up the integral
\int dA = \int ^{\Theta=\pi} _{\Theta=0} \int^{r=R}_{r=0} rdr d\Theta
Can you evaluate the integral?
You haven't stated a problem here! What do you want to integrate from 0 to R? What function are you integrating?
If you just want the area, look at the problem you gave:
(And arildno did not say he had never seen that before, he was trying to get you to think about why you think that was true.)
Suppose your semi-circles radius is R. Then dA= r dr dθ. In a sense, dr here, as well as r, is r: along each radius we go from r= 0 to R so the "change in r", dr, is R.
Okay, then r dr dθ becomes dA= R2 dθ, just like your dX dY became 4dy, the area of the semi-circle is
\int_{\theta=0}^{\pi} R^2 d\theta= \pi R^2, exactly the right answer.
(θ does not go from 0 to 180! As I am sure you learned in when you were learning the derivatives of sine and cosine, in calculus, all angles are in radians.)
(Oh, and by the way, why was this posted under "differential equations". Was this part of a differential equations problem?)
  • · Replies 36 ·
  • · Replies 29 ·
20K
  • · Replies 26 ·
