Semiclassical exact expression ?
  • Context: Graduate
  • Thread starter Thread starter zetafunction
    Expression
The discussion focuses on the equality of two mathematical expressions related to semiclassical approximations in quantum mechanics. Specifically, it establishes that the expressions \( Z(t) = \sum_{n} e^{-tE_{n}} \) and \( U(t) = \int_{0}^{\infty} dx \int_{0}^{\infty} dp \, e^{-tp^{2} - tV(x)} \) are equal under the condition that the potential \( V(x) \) is an even function. The proof relies on properties of Fourier transforms of even functions, demonstrating that the Laplace transform can be decomposed into real and imaginary components, leading to the desired equality.
  • Understanding of semiclassical approximations in quantum mechanics
  • Familiarity with Laplace transforms and their properties
  • Knowledge of Fourier transforms, particularly for even functions
  • Basic concepts of potential functions in quantum systems
  • Study the properties of even functions in Fourier analysis
  • Explore Laplace transforms in the context of quantum mechanics
  • Investigate semiclassical methods in quantum field theory
  • Learn about the implications of potential symmetry in quantum systems
Researchers and students in theoretical physics, particularly those focusing on quantum mechanics and semiclassical methods, will benefit from this discussion.
zetafunction
let be N(x)= \sum_{n} H(x-E_{n}) the eingenvalue 'staircase' function
and let be a system so V(x)=V(-x) and V^{-1}(x)=\sqrt \pi \frac{d^{1/2}}{dx^{1/2}} N(x)<br /> <br /> then would it be true that the two function<br /> <br /> \sum_{n}exp(-tE_{n})=Z(t)= \int_{0}^{\infty}dN(x)exp(-tx)<br /> <br /> and \int_{0}^{\infty}dx\int_{0}^{\infty}dpexp(-tp^{2}-tV(x))=U(t)<br /> <br /> would be equal ?? i have just compared the two results \int_{0}^{\infty}dnN(x)exp(-tx)=\int_{0}^{\infty}dx\int_{0}^{\infty}dpexp(-tp^{2}-tV(x)) i have taken the Laplace transform inside and get the desired result assuming that the potential V(x) is EVEN
. Yes, they would be equal. To prove this, you would need to use the fact that for an even function, its Fourier transform is real and symmetric. This means that the Laplace transform of the even function can be written as a sum of two terms: one term containing the real part of the Fourier transform, and the other term containing the imaginary part. Using this, you can then show that the two functions are indeed equal.
9K
