Proving Infinity of a Sequence: a(n)=[n+7]/[2+sin(n)]
The sequence defined by a(n) = (n + 7) / (2 + sin(n)) tends to infinity as n approaches infinity. L'Hôpital's Rule is not applicable in this case since the denominator does not approach zero or infinity. Instead, by establishing that 1 ≤ 2 + sin(n) ≤ 3 for all n, one can derive both lower and upper bounds for the sequence. As n becomes large, both bounds converge to infinity, confirming that a(n) indeed tends to infinity.
  • Understanding of limits in calculus
  • Familiarity with L'Hôpital's Rule
  • Knowledge of bounded functions and their properties
  • Basic trigonometric functions and their behavior
  • Study the application of L'Hôpital's Rule in different scenarios
  • Explore the concept of bounding sequences in calculus
  • Learn about the behavior of trigonometric functions over intervals
  • Investigate the formal definition of limits and their proofs
Students studying calculus, particularly those focusing on sequences and limits, as well as educators looking for examples of proving the behavior of sequences.
kmeado07
Prove that the following sequence (a(n)) has the property that a(n) tends to infinity as n tends to infinity.
i tried l'hospital's rule, so i got 1/cos(n)...which wouldn't work.
so I am not sure how to do this question.
L'Hopital's Rule doesn't apply here. The quotient has to be of the form 0/0 or infinity/infinity for L'H's Rule to be used.
Instead, use the fact that 1 <= 2 + sin(n) <= 3, for all n to get lower and upper limits on the value of (n + 7)/(2 + sin(n)), and then show that the lower and upper limit expressions both have the same limit as n gets large, thereby trapping the expression in the middle.
Since n+7 is unbounded, to apply l'Hopital to this you would need that the denominator is also unbounded (so you have an infinity/infinity form). It's not. The denominator is bounded and positive. That should tell you the limit right there.
