Series solution for Airy's equation about x=-1
6 replies · 5K views · last reply
mr_coffee
Find a series solution for Airy's equation about x=-1, what does this about x=-1 mean?
Here is Airy's equation:
y''+p(t) y'+q(t) y=0.
THe professor doesn't give any 2nd order Differential equation, just the directions of:
Fridays Homework problem
Is to find a series solution for Airy's equation about x=-1
Can i use this as my equation?
y''-t y=0
and then:
Power series form y(t) equals the sum from n=0 to infinity of a_n t^n.
Series expression y''(t) = sum from n=2 to infinity of n(n-1)a_n t^(n-2).
Infinite series sum over n from 2 to infinity of n(n-1)a_n t^(n-2), minus t times the sum over n from 0 to infinity of a_n t^n, equals 0.
Equation: sum from n=2 to infinity of n(n-1)a_n t^(n-2), minus sum from n=0 to infinity of a_n t^(n+1), equals 0.
Recurrence relation: the sum from n=0 to infinity of (n+2)(n+1)a_{n+2}t^n minus the sum from n=1 to infinity of a_{n-1}t^n equals 0.
Equation: sum from n=0 to infinity of (n+2)(n+1) a_{n+2} t^n = 2·1·a_2 + sum from n=1 to infinity of (n+2)(n+1) a_{n+2} t^n.
Recurrence relation from a power series solution: 2a2 + sum from n=1 to infinity of [(n+2)(n+1)a_{n+2} t^n - a_{n-1} t^n] = 0.
Handwritten-style equation: 2a2 + sum from n=1 to infinity of [(n+2)(n+1)a_{n+2} - a_{n-1}] t^n = 0.
Recurrence relations written as a system: 2a_2 = 0, and (n+2)(n+1)a_{n+2} - a_{n-1} = 0 for all n = 1, 2, 3, ...
These equations are known as the "recurrence relations" of the differential equations. The recurrence relations permit us to compute all coefficients in terms of a0 and a1.
We already know from the 0th recurrence relation that a2=0. Let's compute a3 by reading off the recurrence relation for n=1:
Handwritten-style equation: a_3 = a_0 / (2 · 3).
Recurrence relations for series coefficients: a4 = a1/(3·4), a5 = a2/(4·5) = 0, a6 = a3/(5·6) = a0/((2·3)(5·6)), a7 = a4/(6·7) = a1/((3·4)(6·7)), a8 = a5/(7·8) = 0, a9 = a6/(8·9) = a0/((2·3)(5·6)(8·9)).
But what is this thing all about x=-1?
Thanks!
Either you or your teacher is really confused!
First of all, y"+ p(t)y'+ q(t)y= 0 is NOT "Airy's equation". That is the general form of a linear homogeneous equation with variable coefficients.
Airy's equation, specifically y"- ty= 0, is a special case of that.
Second "solve y"- ty= 0 with a series solution about x= -1" makes no sense because there is no "x" in the equation! You must have either
"Solve y"- ty= 0 with a series solution about t= -1" (y" is understood to be differentiation with respect to t) or "Solve y"- xy= 0 with a series solution about x=-1" (y" is understood to be differentiation with respect to x).
Use [itex]\Sigma a_n (t+ 1)^n[/itex] rather than [itex]\Sigma a_n t^n[/itex]. If, for example, you were given initial conditions at t= -1 rather than t= 0, that form would make it easier to apply them.
Ivey if i already have the general solution to aries equation, can i just make alitle modifcation to it for x= -1?
http://www.soton.ac.uk/~jhr/MA273/img305.png
http://www.soton.ac.uk/~jhr/MA273/img319.png
Ahhh n/m, i c i can't just do that, i will try it with (t+1) like u said! thanks
Did i do this right?>
Ivey and everyone, i think i did this right, its a long problem, but I wrote what i was going to do next so I think its easy to follow, did I do this correctly? This is the first type of problem I did like this so I'm making sure i didn't leave out somthing!
http://suprfile.com/src/1/2ur1zj/lastscan1.jpg
http://suprfile.com/src/1/2us9rp/lastscan2.jpg
Thanks!
I went over it again and i caught a small error i think:
i had
a2 + ao + ...
should have been:
2a2 + ao
wewt.
I presented it today and it was correct! weee!
