Severe Condition (85°C/95% or Water Immersion)
  • Thread starter Thread starter mjjabines
    Condition Water
The discussion revolves around determining the severity of different environmental tests for a product, specifically comparing a Damp Heat Test at varying humidity levels and a Water Immersion Test. The focus is on understanding the implications of each testing condition for product performance over time.
  • Technical explanation, Debate/contested
  • One participant questions which test is more severe: Damp Heat Test (85°C / 85% R.H), Damp Heat Test (85°C / 95% R.H), or Water Immersion Test (85°C at 1 meter depth).
  • Another participant explains that a routine Accelerated Life Test (ALT) for electronic products is conducted at 85% RH and 85°C for 1000 hours, highlighting its role in identifying assembly issues and moisture accumulation.
  • A different participant mentions testing WDM optical components and notes that while 85% RH at 85°C for 1000 hours is standard, they are seeking faster results.
  • A link to a document is provided, suggesting that there may be additional considerations or caveats regarding the tests.
Participants express differing levels of familiarity with the 95% RH test and the Water Immersion Test, indicating that there is no consensus on which test is definitively more severe.
There are limitations regarding the specific conditions and definitions of severity in testing, as well as the potential impact of product type on test outcomes. The discussion does not resolve these uncertainties.
Individuals involved in product testing, environmental testing, or those working with electronic components may find this discussion relevant.
mjjabines
Hello All,
I'm currently testing a product for environmental test but i don't know what test do i conduct for this one.
I would like to ask your help if which is more severe environment.
1. Damp Heat Test (85°C / 85% R.H)
2. Damp Heat Test (85°C / 95% R.H)
3. Water Immersion Test (85°C at 1 meter depth)
And may i know why? thank you...
A routine "Accelerated Life Test" (ALT) for electronic products is 85% RH at 85C for 1000 hours, while powered-up and operating. This test finds problems with assembly methods, cleanliness, and "microclimates" (enclosed areas of the assembly where moisture can accumulate and not evaporate). If you have assembly cleanliness issues and enclosed microclimates (like inside potted assemblies), you can get dendritic growth/migration of copper between traces at different voltages, which eventually leads to the traces shorting out or opening.
I'm not familiar with a 95% RH test, nor a submersion test. What kind of product are you testing?
I'm planning to test WDM optical components quickly at severe environment to see its performance over time.
85% RH at 85C for 1000 hours is a routine test for us but they want a faster results.
http://theriac.org/DeskReference/viewDocument.php?id=61
Read the caveat at the bottom of the pdf
  • · Replies 74 ·
  • · Replies 0 ·
