SHM question (Is my method correct?)
  • Thread starter Faiq
    Method Shm
7 replies · 2K views · last reply
Faiq
A particle P is performing simple harmonic motion with amplitude 0.25m. During each complete
oscillation, P moves with a speed that is less than or equal to half of its maximum speed for 4/3 seconds.
Find the angular frequency of P
First I split 4/3 into two portions, the right and left side. Since both are symmetrical, information about left side will be same as information for right side.
Now 2/3s is the time the particle spend with velocity < 1/2 wx in one side of motion.
So
Time Spent = Time required to achieve max - time required to achieve 1/2 of max
$$ \frac{2}{3} = \omega^{-1} (\sin^{-1}(\frac{Max~V}{Max~V})-\sin^{-1}(\frac{1/2~of~Max~V}{Max~V})) $$
$$ \frac{2}{3} = \omega^{-1} (\sin^{-1} 1 - \sin^{-1} 0.5) $$
$$ \omega = \frac{\pi}{2} $$
Note:- The answer is correct
Now the problem I realized it, even though my answer is coming correct but in my opinion, my method is not correct. The reason is I have calculated the time required by the particle to go from centre to the 1/2 speed points which makes no sense.
So can you tell me whether my method is correct and if not what is the correct method?
Hi,
If you draw a sine and check what fraction of the period the absolute value is < 0.5 the answer is 1/3 .
So 1/3 of a period corresponds to 4/3 s. Thereby : a full period is 4 s, hence ##\omega = \pi/2## as you 'found'.
So
Don't agree: make a drawing.
BvU said:
Hi,
How did you work out the value 1/3?
Î made a drawing but how did you infer the value fo 1/3?
## [0,\pi/6] + [5\pi/6, 7\pi/6] + [11\pi/6, 2\pi] ## totals ##4\pi/6##. And ##4\pi/6 /(2\pi) = 1/3##
Graph of y = sin x from 0 to 2π with angles in degrees and radians marked on the x-axis, and two horizontal red lines near y = ±0.5 marking where the curve lies between them.
