I typed this before I saw that LastOneStanding has already said pretty much the same thing.
Borek said:
I feel like there is some kind of contradiction here.
I don't see a contradiction. Chronos and I are talking about two different things.
The world line of a particle in free fall is a geodesic. But if you fall through the event horizon of a typical black hole, and all the particles in your body move as described by geodesics, you will die quickly because the distance between your feet and your head will be increasing rapidly.
Acceleration is a measure of the deviation from geodesic motion, and force is mass times acceleration, so it takes a
force to prevent your head and feet from moving as described by geodesics, while some part in the middle of your body
is moving as described by a geodesic. The only forces at play here are the internal forces in your body. So your survival of a "free fall" through an event horizon depends on whether those forces are strong enough to keep your body parts at constant distances from each other.
In the case of a very massive black hole, the natural elasticity of your body will generate enough force to keep you intact. In the case of a small black hole, those forces won't be anywhere near enough.
This is what Chronos was talking about. I was talking about the external force (from say the rocket that you're in) that it would take to prevent your speed as you cross the horizon from being much greater than that of a nerve signal. If you fall freely from a great distance, you will obviously accelerate (in Schwartzschild coordinates) to an enormous speed before you get to the horizon. And if you use your rocket engines to descend slowly so that you can jump in from a low altitude, you will be crushed against the floor, because of the rocket's enormous acceleration.
