Show equivalence of propositions
  • Topic:
  • Thread starter Thread starter mathmari
    Equivalence
15 replies · 2K views
mathmari
MHB
Hey! :o
Let $\mathbb{K}$ be a field, $V,W$ finite dimensional $\mathbb{K}$-vector spaces and $\Phi:V\rightarrow W$ a linear map.
I want to show that the following two propositions are equivalent:
  1. $\Phi$ is surjective
  2. For each linear form $\beta:W\rightarrow \mathbb{K}$ it holds:
    Is $\beta\circ\Phi:V\rightarrow \mathbb{K}$ the zero map, then $\beta$ is the zero map.
I have done the following:
$(1)\Rightarrow (2)$
The map $\Phi$ is surjective.
Let $\beta : W\rightarrow \mathbb{K}$ be a linear form.
If $\beta\circ \Phi:V\rightarrow \mathbb{K}$ is the zero map, then it holds that $(\beta \circ \Phi)(v)=0$ for all $v\in V$.
We assume that $\beta$ is not the zero map. Then there is a $w\in W$ such that $\beta (w)\neq 0$.
Since $\Phi$ is surjective, there is a $v\in V$ with $\Phi (v)=w$, for this $v$ it holds \begin{equation*}\beta (\Phi (v))=\beta (w) \Rightarrow (\beta \circ \Phi )(v)=\beta (w)\Rightarrow 0=\beta (w)\neq 0\end{equation*} a contradiction.
So the assumption is wrong, therefore $\beta$ must be the zero map.
Is this direction correct? Could we improve something? (Wondering)
$(2)\Rightarrow (1)$
We assume that $\Phi$ is not surjective.
Could you give me a hint for that direction? (Wondering)
mathmari said:
Hey! :o
Hey mathmari!
It looks just fine to me. (Nod)
If $\Phi$ is not surjective, then there must be a $w$ in $W$ that does not have an original in $V$.
Then we can choose a $\beta$ such that $\beta(w)\ne 0$ can't we? (Thinking)
Why can we do that? (Wondering)
We start with: For each linear form β:W→K it holds: Is β∘Φ:V→K the zero map, then β is the zero map.
Now suppose we can find a β such that β∘Φ is the zero map, but β is not.
Doesn't that mean that we have a contradiction meaning the assumption of surjectivity must be wrong? (Wondering)
I got stuck right now. At the direction $(2)\Rightarrow (1)$ do we suppose that the statement (2) "For each linear form β:W→K it holds: Is β∘Φ:V→K the zero map, then β is the zero map." is not true? (Wondering)
Nope.
We assume that statement (2) is true.
Then we assume that $\Phi$ is not surjective.
If we can prove that that leads to a contradiction in (2), we're done.
And we have a contradiction if we can find a linear β for which the implication is false. (Thinking)
I like Serena said:
Nope.
We assume that $\Phi$ is not surjective, so there is a $w\in W$ that does not have an original in $V$.
That means that $\Phi(v)\neq w$ for all $v\in V$.
Then we apply here $\beta$ and we get $\beta (\Phi (v))\neq \beta (w) \Rightarrow (\beta \circ \Phi) (v)\neq \beta (w)$.
We have that if $\beta\circ \Phi$ is the zero map, then $\beta$ is the zero map.
But if $\beta\circ \Phi$ is the zero map then we also have that $0\neq \beta (w)$ and so $\beta$ is not the zero map. A contradiction. Is everything correct? (Wondering)
We can't just say that $\beta (\Phi (v))\neq \beta (w)$ can we?
We do have that $\beta (\Phi (v))=0$, but $\beta (w)$ can still be $0$ as well.
What we need is a $\beta$ that is not the zero-map. (Thinking)
Why does this hold? I got stuck right now. (Wondering)
Let's draw a picture.
\begin{tikzpicture}[>=stealth',
bullet/.style={fill=black, circle, minimum width=1pt, inner sep=1pt},
projection/.style={ ->,thick,shorten <=2pt,shorten >=2pt },
every fit/.style={ellipse,draw,inner sep=0pt}]
%preamble \usepackage{amsfonts}
%preamble \usetikzlibrary{fit,shapes,arrows}
\foreach \y/\l in {0/0, 1/v_1,2/v_2,3/v_3, 4/v_4}
\node[bullet,label=left:$\l$] (v\y) at (0,\y) {};
\foreach \y/\l in {0/0, 1/w_1,2/w_2,3/w_3}
\node[bullet,label=above:$\l$] (w\y) at (4,\y) {};
\foreach \y/\l in {0/0, 1/1,2/2}
\node[bullet,label=right:$\l$] (k\y) at (8,\y) {};
\node[draw,fit=(v0) (v4),minimum width=1.5cm,label=above:$V$] {} ;
\node[draw,fit=(w0) (w3),minimum width=1.5cm,label=above:$W$] {} ;
\node[draw,fit=(k0) (k2),minimum width=1.5cm,label=above:$\mathbb K$] {} ;
\draw[projection] (v4) -- node[above] {$\Phi$} (w1);
\draw[projection] (v3) -- (w1);
\draw[projection] (v2) -- (w1);
\draw[projection] (v1) -- (w0);
\draw[projection] (v0) -- (w0);
\draw[projection] (w3) -- node[above] {$\beta$} (k0);
\draw[projection] (w2) -- (k0);
\draw[projection] (w1) -- (k0);
\draw[projection] (w0) -- (k0);
\end{tikzpicture}
This is an example where $\Phi$ is not surjective and $\beta$ is the zero map.
The set $\{v_i\}$ is a basis of $V$ and $\{w_j\}$ is a basis of $W$.
However, the implication in statement (2) must hold for any $\beta$.
So let's pick a $\beta$ that maps $w_3$ to $1$.
\draw[projection] (w3) -- node[above] {$\beta$} (k1);
\end{tikzpicture}
Now the linear $\beta$ is not the zero map, but we still have that $(\beta\circ\Phi)(V)=\{0\}$ don't we?
Therefore the implication in statement (2) is false.
So it is not for every $\beta$ that the implication is true.
Thus statement (2) is false completing the proof by contradiction. (Thinking)
Ah I understood that now! (Nerd)
Is the proof using these pictures formal? (Wondering)
Good! (Happy)
I'm afraid not. (Shake)
The proof should be standing on its own.
Pictures should only illustrate what is intended to help people understand a proof. (Nerd)
Ah ok.. But how does the formal proof look like in this case? (Wondering)
I think you almost already had it.
Can you finish it? (Wondering)
I got stuck right now. I don't really know how to continue formally as a proof. Could you give me a hint? (Wondering)
How about we make it:
(2)⇒(1)
Is β∘Φ:V→𝕂 the zero map, then β is the zero map.
We pick $\beta$ such that $\beta (\Phi (V))=\{0\}$ and $\beta(w)\ne 0$.
Consequently the initial implication is false completing the proof by contradiction.
