Show that each such group is solvable
  • Topic:
  • Thread starter mathmari
    Group
13 replies · 3K views · last reply
mathmari
MHB
Hey! :o
I am looking at the following exercise:
Each group of order $p^2q$, with $p,q$ different primes, is solvable.
To show this can we just say that it holds according to Burnside's Theorem ? (Wondering)
You could...but it is easier to prove it directly, rather than prove Burnside's Theorem, which is a bit "deep" (representation theory is probably a bit beyond what you are studying at the moment).
For simplicity's sake, let $n_p = |\text{Syl}_p(G)|$.
If $|G| = p^2q$ then if $G$ is simple, $n_p = q$.
Also, we have $n_q = p$ or $n_q = p^2$.
Show that $n_q = p^2$ leads to "too many elements of $G$".
So the "hard case" is $n_q = p$.
First, prove this lemma:
Lemma: Let $G$ be a finite group, and $r$ a prime number such that $r$ divides $|G|$. If $G$ is simple, then $n_r > r$.
This should lead you to an easy contradiction.
In my notes we have proven the lemma:
$|G|=pq^2$ then $G$ is not simple. So, I can use that without proving it again, or not? (Wondering) How can we use the fact that the group is not simple? (Wondering)
If you've read and understood the proof, then sure, go ahead and use it. But..
...since we want to show $G$ is solvable, it would be good to know what normal subgroups we have, not just that we have "one" (or more).
If you follow the steps I have outlined above, you will find that there is a subgroup $N$ such that either:
a) $|G/N| = q$
b) $|G/N| = p^2$.
Either way, the factor group is abelian, so $G$ is solvable (some definitions require the factor groups to be cyclic, or cyclic of prime order, but this poses no real difficulty-why?).
Proof:
Since $r$ divides $|G|$, we have that there is a $r$-Sylow in $G$.
$n_r$ divides $|G|$ and is congruent to $1\pmod r$, i.e., $n_r=1+kr$.
That means that either $n_r=1$ or $n_r>r$.
When $n_r=1$ then the Sylow is unique so it is normal in $G$, so $G$ is not simple, a contradiction.
Therefore, $n_r>r$.
Is this correct? (Wondering)
We have that $|G|=p^2q$.
We have that $n_p\mid |G| \Rightarrow n_p=1+np\mid p^2q \Rightarrow n_p\mid q \Rightarrow n_p\in \{1, q\}$ and $n_q\mid |G| \Rightarrow n_q=1+mq\mid p^2q \Rightarrow n_q\mid p^2 \Rightarrow n_q\in \{1, p, p^2\}$.
If $G$ is simple, according to the lemma we have that $n_p>p$ and $n_q>q$.
So, $n_p$ must be equal to $q$, where $q>p$.
Since $n_q>q$ and $q>p$, it cannot be that $n_q=1$ or $n_q=p$. So it must be $n_q=p^2$.
Therefore, we have $p^2$ $q$-Sylow in $G$. That means that we have $p^2(q-1)=p^2q-p^2$ elements of order $q$.
Since $|G|=p^2q$, we can have only one $p$-Sylow ( $|P|=p^2$ ).
So, $n_p=1$, a contradiction.
Therefore, $G$ is not simple.
So, we have one $p$-Sylow of order $p^2$, which is normal, right? (Wondering)
a) |G/N| = q
b) |G/N| = p^2.
Having a normal $p$-Sylow of order $p^2$, say $N$, we have that $|G/N|=\frac{|G|}{|N|}=\frac{p^2q}{p^2}=q$, right? (Wondering)
Do we have that each group of order a power of a prime, is abelian? (Wondering)
How do we conclude then that $G$ is solvable? (Wondering)
Proof:
Therefore, $n_r>r$.
Yes.
Yes.
Not necessarily. All we showed above is that $G$ has a normal Sylow subgroup, it might be the $p^2$ one, or the $q$ one. For example, in $A_3$ ($p = 2,q = 3$) it's the Sylow $2$-subgroup that is normal (this group is:
$V = \{e,(1\ 2)(3\ 4), (1\ 3)(2\ 4), (1\ 4)(2\ 3)\}$), whereas in $D_6$ (the dihedral group of order $12$) it's the Sylow $3$-subgroup:
$\langle r^2 \rangle = \{1,r^2,r^4\}$
that is normal.
That is one possibility, you must consider both.
No, there exist non-abelian groups of order $p^k$ for $k > 2$. But we need not concern ourselves with that. Here, the only two possibilities are:
$|G/N| = q$ (all groups of order $q$ are abelian, in fact, they are cyclic, and simple).
$|G/N| = p^2$ (all groups of order $p^2$ are abelian...why?)
What can you say about the normal series:
$1 \lhd N \lhd G$?
(in either case)?
that is normal.
Ah ok... (Thinking)
We have that a group of order a prime $q$ is cyclic due to Lagrange's Theorem, right? (Wondering)
We have that the order of each element of the group must divide the the order of the group, $q$.
The divisors of $q$ are $1$ and $q$.
Only the identity has order $1$. So, all the other elements must have order $q$.
Therefore, the group is cyclic, right? (Wondering)
Since $|A|=q$, we have that there are $q$-Sylow in $A$.
We have that $n_q=1+kq$ and $n_q\mid q$. That means that $n_q=1$, or not? (Wondering)
$1 \lhd N \lhd G$?
(in either case)?
In both cases, we have that $G/N$ is abelian, as mentioned above and $N/1=N$ is also abelian.
Therefore, $G$ is solvable, right? (Wondering)
mathmari said:
Ah ok... (Thinking)
Yep.
I'm not sure what your "$A$" is, here. We're only using the Sylow theory to show one of the Sylow subgroups is normal. This gives us the normal series we need to show $G$ is solvable.
Indeed, from the definition of solvable.
Why are all groups of order $q$ are abelian? (Wondering)
I got stuck right now...
Because $q$ is a prime...
We have that when $|G|=p^n$ for some $n$ then $Z(G)\neq 1$.
A group $G$ of order $|G|=q$, where $q$ is a prime is abelian:
We have that $Z(G)\neq \{1\}$, because of the above sentence.
So $|Z(G)|\neq 1$.
Since $|Z(G)|\mid |G|$, we must have that $|Z(G)|=|G|$.
Does this mean that $G=Z(G)$ ? (Wondering)
If that is true, it implies that $G$ is abelian, right? (Wondering) A group $G$ of order $|G|=p^2$, where $p$ is a prime is abelian:
So $|Z(G)|\neq 1$.
Since $|Z(G)|\mid |G|$, we must have that $|Z(G)|\in \{p, p^2\}$.
If $|Z(G)|=p^2$, then $G=Z(G)$, so $G$ is abelian, right? (Wondering)
If $|Z(G)|=p$, then $|G/Z(G)|=\frac{|G|}{|Z(G)|}=\frac{p^2}{p}=p$. So $G/Z(G)$ is cyclic. Does this imply that $G$ is abelian? (Wondering)
So $|Z(G)|\neq 1$.
It's even simpler that that: if $q$ is a prime, and $|G| = q$, then if $x \neq e$ is a non-identity element of $G$, the order of $x$ must be $q$ (since the order of $x$ divides $q$, and the order of $x$ is not 1, since $x \neq e$). Hence $x$ generates $G$, that is, $G$ is cyclic of order $q$. Of course, every cyclic group is abelian.
So $|Z(G)|\neq 1$.
Yes, it does (sort of, because it can't happen that way)...do you know why?
Ah ok... I see... (Thinking)
Not really... Could you explain it to me? (Wondering)
Theorem: If $G/Z(G)$ is cyclic, $G$ is abelian.
Suppose $G/Z(G) = \langle xZ(G)\rangle$.
Since the cosets of $Z(G)$ partition $G$, we can write $g_1,g_2 \in G$ as:
$g_1 = x^kz_1$, for some $k$ and $z_1 \in Z(G)$ and
$g_2 = x^mz_2$, for some $m$ and $z_2 \in Z(G)$.
Then $g_1g_2 = (x^kz_1)(x^mz_2) = (x^kz_1)(z_2x^m) = x^k(z_1z_2)x^m$
$= x^kx^m(z_1z_2)$ (since $Z(G)$ is a subgroup, and thus $z_1z_2 \in Z(G)$ and commutes with all of $G$)
$= x^{k+m}(z_1z_2) = x^{m+k}(z_1z_2) = (x^mx^k)(z_1z_2)$
$= x^m(x^kz_1)z_2 = x^m(z_2(x^kz_1)) = (x^mz_2)(x^kz_1) = g_2g_1$,
so $G$ is abelian. (And then $Z(G) = G$, so $G/Z(G)$ is the cyclic trivial group of order 1).
