Show the identity ##\vec{\nabla}(\vec{r} \cdot \vec{u})##
12 replies · 2K views
Redwaves
Show the identity ##\vec{\nabla}(\vec{r} \cdot \vec{u}) = \vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\vec{L} \times \vec{u})##, ##\vec{L} = \frac{\vec{r}}{i} \times \vec{\nabla}##
First of all, sorry for the title I don't know the name of this formula and that's part of the problem, I can't find anything on google.
I have to show the identity above. Here's what I did. I don't know if this is correct so far.
##\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\vec{L} \times \vec{u})##
= ##\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\frac{\vec{r}}{i} \times \vec{\nabla} \times \vec{u})##
= ##\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\vec{\nabla}(\frac{\vec{r}}{i} \cdot \vec{u}) - \vec{u}(\frac{\vec{r}}{i} \cdot \vec{\nabla}))##
= ##\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + \vec{\nabla}(\vec{r} \cdot \vec{u}) - \vec{u}(\vec{r} \cdot \vec{\nabla})##
Is there a specific name for this identity?
I would start with the vector identity for ##\vec \nabla (\vec A\cdot \vec B)=\dots## and rewrite each of the 4 terms on the right-hand side.
Use suffix notation
\begin{align*}
L_j &= \dfrac{1}{i} \epsilon_{jlm} x_l \partial_m \\
\implies i (\mathbf{L} \times \mathbf{u})_i &= \epsilon_{ijk} \epsilon_{jlm} x_l \partial_m u_k \\
&= (\delta_{kl} \delta_{im} - \delta_{il} \delta_{km})x_l \partial_m u_k \\
&= x_k \partial_i u_k - x_i \partial_k u_k \\
&= x_k \partial_i u_k - (\nabla \cdot \mathbf{u}) x_i
\end{align*}also\begin{align*}
(\nabla(\mathbf{r} \cdot \mathbf{u}))_i = \partial_i (x_k u_k) &= u_k \partial_i x_k + x_k \partial_i u_k \\
&= u_i + x_k \partial_i u_k
\end{align*}
now can you see?
My bad, I forgot to mention that ##i = \sqrt{-1}##
That's why I replaced ##\vec{L}## to get rid of i's
there is no ambiguity in using the letter ##i## to denote both the imaginary unit and a vector index, since it is obvious from context
see post #3
ergospherical said:
Use suffix notation
\begin{align*}
\end{align*}
now can you see?
Is it the only way? I never used the suffix notation yet.
There is. See post #2.
I was working on it, but I wasn't sure since I can't get it work.
On the left hand side I get ##\vec{\nabla}(\vec{r}\cdot \vec{u}) = \vec{\nabla}(\vec{r}\cdot \vec{u}) + \vec{\nabla}(\vec{u} + \vec{r}))##
It doesn't work, but I can't figure out where are my errors.
Using https://en.wikipedia.org/wiki/Vector_calculus_identities#Dot_product_rule
and "bac cab" for the triple cross product.
Use
##\vec \nabla (\vec A\cdot \vec B)=(\vec A \cdot \vec \nabla)\vec B+\vec A\times(\vec \nabla \times \vec B) + (\vec B \cdot \vec \nabla)\vec A+\vec B\times(\vec \nabla \times \vec A).##
Let ##\vec A = \vec r## and ##\vec B=\vec u##. This is the brute-force method. Write it all out and unless you really, really know what you're doing don't use bac-cab for the triple cross product.
kuruman said:
Use
If I want to get rid of the cross products to have all the dot products to match the right hand side, I don't see how otherwise.
Maybe the answer I found for the right hand side isn't correct neither since I used bac-cab to get rid of the i's
I find the use of brute-force method and suffix notations both tedious and cumbersome. Why don't you try using first useful vector identities to simplify your equation. The BAC minus CAB rule is one such useful identity.
But I noticed in your OP where you wrote:
Redwaves said:
##\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\vec{L} \times \vec{u})## = ##\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\frac{\vec{r}}{i} \times \vec{\nabla} \times \vec{u})##
that you didn't properly group together the factors in the third term on the right hand side. You should have written
##\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\vec{L} \times \vec{u})## = ##\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i[ (\frac{\vec{r}}{i} \times \vec{\nabla}) \times \vec{u} ]##
The OP posted this problem-to-prove question:
Redwaves said:
Homework Statement:: Show the identity ##\vec{\nabla}(\vec{r} \cdot \vec{u}) = \vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\vec{L} \times \vec{u})## , ##\vec{L} = \frac{\vec{r}}{i} \times \vec{\nabla}##
... don't know if ... correct ... ##\vec{\nabla}(\vec{r} \cdot \vec{u}) =\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\vec{L} \times \vec{u}) = \vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\frac{\vec{r}}{i} \times \vec{\nabla} \times \vec{u})## ...
As I already said in post #11, the correct simplification should lead to$$\vec{\nabla}(\vec{r} \cdot \vec{u}) = \vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + [~(\vec r \times \vec{\nabla}) \times \vec{u}~]$$But I was wondering if the identity to be proven shouldn't have been written$$\vec{\nabla}(\vec{r} \cdot \vec{u}) = 3\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + i(\vec{L} \times \vec{u})$$with an additional factor of 3 in the first term on the right hand side, so that it eventually simplifies to$$\vec{\nabla}(\vec{r} \cdot \vec{u}) = 3\vec{u} + \vec{r}(\vec{\nabla} \cdot \vec{u}) + [~(\vec r \times \vec{\nabla}) \times \vec{u}~]$$It would be easy to get that additional factor if the term ##\vec{u}(\nabla \cdot\vec{r}~)## could somehow be incorporated in the equations while doing the vector algebra.
Suffix/index-notation is great to prove or derive the identities.
One could also look at one component of a vector identity, and do the others accordingly.
But once you have the identities, it's probably better to just use them [especially if the index notation is unfamiliar].
By the way, this seems a little advanced for "introductory physics".
