Showing the quotient is not a UFD
  • Thread starter Thread starter Kreizhn
    quotient
The discussion centers on proving that the quotient ring \(\mathbb{Q}[x,y]/(x^2+y^2-1)\) is not a unique factorization domain (UFD). Participants explore various approaches, including examining irreducibility and prime factorization, ultimately concluding that elements can be irreducible without being prime. The attempts to apply Eisenstein's criterion are hindered by the properties of prime ideals in \(\mathbb{Q}\), leading to the realization that the degree of equivalence classes in the quotient is not well-behaved, complicating the proof.
  • Understanding of unique factorization domains (UFDs)
  • Familiarity with polynomial rings and quotient rings
  • Knowledge of irreducibility and prime elements in ring theory
  • Experience with Eisenstein's criterion for irreducibility
  • Research the properties of quotient rings, specifically \(\mathbb{Q}[x,y]/(x^2+y^2-1)\)
  • Study the definitions and implications of irreducible and prime elements in ring theory
  • Explore Eisenstein's criterion and its limitations in various contexts
  • Investigate degree arguments in polynomial factorization within quotient rings
Mathematicians, algebraists, and students studying ring theory, particularly those interested in unique factorization domains and polynomial rings.
Kreizhn
Show that \mathbb Q[x,y]/(x^2+y^2-1) is not a unique factorization domain.
We have tried a few approaches. Using [] to denote equivalence classes, we note that we can write [x]^2 = [1-y][1+y]. Our goal was to show that this is a non-unique prime decomposition, but this doesn't work since neither of these elements are prime. Similarly, [x+y-1][x+y+1] = [2x][y] but the same problem applies.
Next we tried playing around with evaluations of polynomials. In particular, in the quotient ring we can write any element as p(x) + y q(x). Taking a product of such polynomials and evaluating at zero gives a structure similar to \mathbb C.
Another suggestion was to use Laurent polynomial. Any ideas?
Does your definition of UFD require a unique decomposition into primes or a unique decomposition into irreducibles?
Both. They are equivalent in a UFD no?
If it's not a UFD then it's not the same thing (namely, elements can be irreducible without being prime). So your first attempt at x2=(1-y)(1+y) is a good place to look... it's not a prime factorization, but they are irreducible factorizations
Yeah, that had occurred to me, though I'm not too sure how to show that 1 \pm y is irreducible. It seems obvious since they're monic first order polynomials, but I don't think I can just claim that (can I?). In any case, I would like to use Eisenstein's criterion but then I run into the problem of dealing with the prime ideals of \mathbb Q, of which there are no non-trivial proper ideals. Should I perhaps be looking at the prime ideals of in \mathbb Q[x] instead?
I fear you need to start with the very definition of irreducible. You ring is pretty strange, so you can't use Eisenstein.
Assume that y+1=b*c and obtain a contradiction.
I think what you're hinting at is a degree argument, in that the only way that product could be a first order polynomial is precisely when one is a constant and the other is a first order polynomial. Since \mathbb Q is a field, the constant is a unit, so we can conclude that 1-y is irreducible. However, does this necessarily apply in the quotient? Degree of equivalence classes is definitely not preserved in the quotient so I don't see how that argument would work.
Edit: The degree of the product of equivalence classes of polynomials in the quotient is not well behaved, is what I meant to say. That's a mouthful!
A direct attack would indeed not work. But let's look at it this way:
Assume
[y+1]=[P(x,y)][Q(x,y)]
Then
y+1-P(x,y)Q(x,y)\in (x^2+y^2-1)
So
y+1-P(x,y)Q(x,y)=R(x,y)(x^2+y^2-1)
and now try to obtain a contradiction.
Sorry. I've been trying to play around with this but I don't see it.
Okay. So I don't think this is a degree argument. I say this because there is no restriction on the degree of x in this case. The degree of y could have lead somewhere, but the presence of the -1 really means that y can take on any degree.
So I'm guessing this is a divisibility argument. I tried arguing that by re-arranging, we could get
(y+1)(R(x,y)(y-1) - 1) = -P(x,y)Q(x,y) - R x^2
in which case since y+1 divides the left hand side, it must also divide the right hand side. Though I don't see anything coming from this.
If I could show that [x] is irreducible and that the only the image of constants in \mathbb Q[x,y]/(x^2+y^2-1) are units, could I show that it is not a UFD?
