Crude Oil Storage Tank Mixer Sizing for Optimal Sediment & Water Control
  • Thread starter Thread starter Amir Sedieqy
    Sizing
The discussion focuses on sizing mixers for a crude oil storage tank with a volume of 98,500 cubic meters, emphasizing the importance of sediment and water control. Participants recommend consulting Penberthy for sizing methods and refer to the 9th Edition of the Chemical Engineers' Handbook by Perry and Chilton for theoretical insights. A significant distinction exists between "off bottom suspension" and "complete mixing," necessitating empirical knowledge for accurate sizing. Engaging with sales engineers to clarify assumptions in their quotes is crucial for making informed purchasing decisions.
  • Understanding of mixer theory and applications
  • Familiarity with empirical methods in mixing processes
  • Knowledge of the differences between off bottom suspension and complete mixing
  • Access to the Chemical Engineers' Handbook, 9th Edition
  • Research Penberthy's mixer sizing recommendations
  • Study empirical methods for mixer sizing in crude oil applications
  • Learn about the implications of mixing precipitated versus ground calcium carbonate
  • Engage with mixer manufacturers to discuss specific project requirements and assumptions
Engineers, procurement specialists, and project managers involved in the design and operation of crude oil storage facilities, particularly those focused on optimizing mixing processes for sediment and water control.
Amir Sedieqy
I'm involved in purchasing a set of mixers for crude oil storage tank. The tank volume is around 98,500 cubic meter. The main purpose of the mixers is base Sediment & water control (cleaning). Deferent vendors offered different number of mixers with different required horsepower. I'm looking for some calculation or methods to size the mixers myself, so I'll be able to compare these offers.
I'd look at Penberthy for recommendations on this. They should have methods for calculating what you are doing.
My 5th Edition of the Chemical Engineers' Handbook by Perry and Chilton has an excellent section on mixing. This book is currently in the 9th Edition with a slightly different title: https://www.amazon.com/dp/0071834087/?tag=pfamazon01-20. Highly recommended.
There is a large difference in mixer size and power between "off bottom suspension" and "complete mixing". You will find that trying to calculate mixer size by theory alone cannot be done. Empirical knowledge is necessary. Mixer manufacturers normally have that knowledge, but even they sometimes learn something the hard way. As an example, I was involved in a project where the mixer manufacturer learned an expensive lesson on the difference between mixing precipitated calcium carbonate and ground calcium carbonate of the same particle size and concentration.
Your best approach is to first study mixing sufficiently to get a general knowledge of mixer theory, such as the section in Chemical Engineers' Handbook. Then go over the quotes with the sales engineers and discuss off bottom suspension vs complete mixing, and what assumptions they made in the quotes. Listen very carefully - are they quoting a large mixer that is larger than necessary, or a smaller mixer that will probably be sufficient.
  • · Replies 39 ·
15K
10K
