Sig fig question: Adding 3000 + 1.234
  • Context: High School
  • Thread starter Thread starter barryj
47 replies · 6K views
bob012345 said:
I'm just saying that the calculator is not incorrect and should not be interpreting numbers for the user. It just adds raw numbers and leaves the interpretation and rounding to the student.
Read my post. I did NOT say the calculator was incorrect, I said it incorrectly gives an answer to the specific problem on the hypthetical quiz and that students should be aware of that. I stand by that statement.
Sorry, I understand. I think we are both saying it is the student's responsibility to understand the limitations of using a calculator wrt significant digit quiz problems.
Reply
Yes, but even more than that I think there are great limitations inherent in the idea of a "significant digit calculator", and even a "significant digit quiz", because there can be no answers that are unconditionally correct, they will always be subject to context and interpretation.
I disagree. If a question specifically states something like "using standard rounding, show your result to 3 significant digits", that is unambiguous and not subject to interpretation, is it not?
Yes this is true, and in the UK education system at least this is generally the only way in which SF is used. However this is very different from the notion of a "significant figure quiz" where you are presented with ridiculous questions like "what is 3,000 + 1.234" and are supposed to guess or memorize arbitrary rules for inferring what is required.
Reply
Agreed
barryj said:
I tutor high school students in chemistry. Sig figs is an important topic in the class so I best understand it.
If the lab notes say add 3 grams of something should one round everything to 1 significant digit?
Add 3 grams isn't a measurement, so doesn't take sig figs. The amount you measure and then add is a measurement. If you aren't precise enough to say it was 3.0 grams, then yeah you're stuck
Reply
malawi_glenn said:
This is why we invented scientific notation, to avoid such confusion.
No, it is not. We invented scientific notation so as to not have to write out dozens of zeros for large numbers.
Reply
Yeah true, that is the main reason ;)
As others have pointed out, sig figs are basically just a lazy person's error analysis, and the answer will depend on the convention used (the one OP references is the one I learned in high school (late 90's): that "3000" has one sig fig while "3000." with a decimal after the trailing zero has 4 sig figs, etc.). That said, OP is a high school chemistry tutor and many high school assignments nowadays are on computers, coded poorly, with basically no tolerance for answers which deviate even slightly from the preprogrammed ones. So the question is a valid one, but not one we can answer here. The proper answer would come from whatever convention the teacher or web course designer had chosen. It's less a mathematical exercise than an exercise in the ability of students to follow received conventions.
Also ##6\times 4 = 4\times 4 = 20## :smile:
Reply
Please, you guys aren't fooling anyone. Scientific notation and sig figs were invented to confuse lay people and keep them in the dark, thus ensuring job security for the elites.
Reply
  • Haha
Actually, scientific notation predates zero in Western math by about 1400 years. It was the lack of a concept of zero and of positional notation that triggered it.
Reply
Source?
(runs and hides...)[/size]
Archimedes came up with something very much like scientific notation in his work The Sand Reckoner - or whatever that works out to in Greek c. 200 BC. Zero and positional notation started to take root in Europe c. 1200 AD. Fibonacci was instrumental in that.
Similar problems arise with basic statistics if you, your soft-ware or your 'trad' button-box use the 'wrong' algorithm to calculate eg standard deviation. Small differences between large numbers can easily trip you up.
I had a situation where my stats calculator gave a sufficiently different answer to a colleague's for a remarkably simple data-set that I just had to go digging.
I ended up generating a 'family tree' of the math cores of all the calculator variants in our labs, along with comparable results from eg Excel and a 'very long precision' package on my A410/1...
My unsettling report got us issued with a calculator version with enough internal significant figures to side-step the issue...
Another time, I got into trouble for quoting a calibrated solution's factor to 4 DP instead of our usual three. Yeah, well, the initial 3 DP factor was giving 'unacceptable' results for a product. So I kept calibrating and calibrating until it was beyond even unreasonable doubt. Still took a 'second opinion' to confirm a 'totally bullet-proof' process had suffered an implausible 'murphy bomb'....
