Significant figures in Results and Confidence Intervals
The discussion centers on how to express confidence intervals with the appropriate number of significant figures in lab reports. The user seeks clarity on whether confidence intervals should be rounded and the implications of rounding on the accuracy and interpretation of the intervals. It is noted that leaving confidence intervals un-rounded may better reflect the true mean's probability, while rounding could introduce false precision. However, the consensus is that there is no universally correct approach, as it largely depends on the conventions and standards being followed in the specific context. Ultimately, the decision on rounding should balance precision with clarity in reporting results.
magin
Hello physicsforum people,
I'm not sure how many significant figures I should express a confidence interval to. I have confidence intervals for means that I need to express in a lab report, which I am going to do in the something ± something fashion. (I have assumed a normal distribution of the deviations of each measurement about the true mean, although it is not the calculation of the confidence intervals I have a problem with)
The resultant something ± something else confidence interval should be accurate to arbitrary precision shouldn't it? (neglecting the fact that you would have used a finite precision computer to calculate it)
If I were to round the bit left of the ± sign, I would shift the interval and if I round the bit to the right, I would narrow/broaden the interval. I am figuring that when making 95% confidence intervals in general, if you leave them un-rounded they will have a probability of containing the true mean closer to 95%, which is what I want, correct?
So why would someone round one, other than to the precision at which the computer can calculate it? I know the rationale behind rounding is to avoid false precision, but when you are explicitly stating precision, I do not believe this is a problem.
Thanks,
Sam
come on people, surely this is an easy question to answer. Can I rephrase it in a better way?
No, it's not an "easy" question because it depends entirely upon what conventions you want to use. There simply is NO correct answer.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
