Simple Fluids Problem: Cylinder on Oil with Added Weight
  • Thread starter Thread starter BlueDevil14
    Fluids
The problem involves a cylindrical disk of wood floating on a column of oil, with questions related to gauge pressure and changes in pressure due to added weight. The subject area includes fluid mechanics and pressure calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of gauge pressure and the effects of adding weight on the wood. Questions arise regarding the relationship between pressure changes at different points in the fluid and the reasoning behind subtracting certain pressure values.
The discussion is active, with participants exploring the implications of adding weight to the wood and questioning the assumptions about pressure changes at different depths. Some guidance has been offered regarding the correct approach to calculating the new pressure after adding weight.
Participants are working within the constraints of the problem statement and are clarifying their understanding of pressure changes in a fluid system without resolving all uncertainties.
BlueDevil14
A cylindrical disk of wood weighing 47.0 N and having a diameter of 30 cm floats on a cylinder of oil of density 0.850 g/cm^3 (the figure). The cylinder of oil is 75.0 cm deep and has a diameter the same as that of the wood.
a) What is the gauge pressure at the top of the oil column?
b) Suppose now that someone puts a weight of 88.0 N on top of the wood, but no oil seeps around the edge of the wood. What is the change in pressure at the bottom of the oil?
c) What is the change in pressure at the halfway down in the oil?
a) [tex]P=\frac{F}{A} \Rightarrow P=\frac{47.0 \mathrm{N}}{.071 \mathrm{ m}^3}=665 \mathrm{ Pa}[/tex]
this answer is correct
b) why would the pressure change at the bottom not be equal to the pressure change at top. i.e 1245 Pa - 665 Pa?
Why are you subtracting 665 Pa?
I was thinking the change in pressure a the bottom would be equal to the change in pressure at the top, and the final-initial at top would be 1245-665 Pa.
That makes sense.
When you add the weight onto the wood, how much does the pressure increase?
oh... I forgot to add the weights!
then in should be [tex]P_{2}=\frac{(47.0+88) \mathrm{N}}{.071 \mathrm{ m}^3}=1901 \mathrm{ Pa}[/tex]
It is therefore 1901-665 not 1245-665
Thanks, it sometimes just requires someone to point out the obvious for you
