Simple hexadecimal addition question
The correct sum of the hexadecimal numbers x1100 and x3301 is x4401. Multiple methods confirm this result, including direct hexadecimal addition and binary conversion. The decimal equivalents of x1100 (4352) and x3301 (13057) add up to 17409, which converts back to x4401 in hexadecimal. Users are advised to ensure the accuracy of their inputs when using platforms like WebAssign, as discrepancies may arise from input errors.
  • Understanding of hexadecimal number system
  • Familiarity with binary number conversions
  • Basic arithmetic operations in different numeral systems
  • Experience using scientific calculators, such as the TI-89 or Windows Calculator
  • Learn hexadecimal addition techniques
  • Explore binary to hexadecimal conversion methods
  • Study the functionality of scientific calculators for numeral conversions
  • Investigate common pitfalls in online homework platforms like WebAssign
Students studying computer science, mathematics, or engineering who need to understand hexadecimal arithmetic and conversions, as well as anyone using online educational tools for homework assignments.
neshepard
I have to hex numbers, x1100 and x3301, that I want to add. I tried to convert them to binary and and them, then convert back to hex-wrong. Tried a straight 1100+3301 addition with the answer being hex, and even used my ti-89 to add them, it can do conversions so why not.
For the conversion to binary and back I got x4401- told me it's wrong.
For the straight hex addition I got x4402-told me it's wrong.
For the ti-89 I got x1131-and of course it's wrong.
How do I add these and what is the answer?
You add them like you would in base 10, only using base 16 symbols and doing carries for sums >= 16. Your problem is very simple though, since hex symbols and carries >=16 don't occur:
Code:
1100
3301
4401
Converting to binary works similarly, with base 2 symbols and carries for sums >=2:
Code:
  1000100000000
 11001100000001
100010000000001
0b100010000000001 = 0x4401
The calculator in Windows does it OK. Switch it to Scientific mode.
The answer is 4401 which you can confirm by converting everything to decimal and adding in decimal
1100 hex is 4352 decimal
3301 hex is 13057 decimal
decimal total =17409 which is 4401 in hex.
Thanks. I got that answer and webassign said it was wrong so I will find out from the professor what the deal is.
I added them in hex, got 4401 hex, and converting to decimal, 17409 decimal. Same as you. And 100010000000001 binary.
To the OP: If the webassign solution is telling you it's wrong, well, then, it certainly wouldn't be the first time an instructor got the answer wrong! However, before you accuse him of getting a wrong answer, please make sure you copied the original two numbers correctly!
11K
