How Do You Find the Velocity of a Particle Given Its Position Function?
  • Thread starter Thread starter JoshHolloway
    Vector
To find the velocity of a particle given its position function r = (5i + 4j)t^2, one must take the derivative of the position function with respect to time. The correct approach is to differentiate directly without distributing the t^2 first, as the coefficients are constants. The resulting expression for velocity is v = (10ti + 8tj) m/s. This method applies to both instantaneous and average velocity calculations. Understanding the differentiation process is crucial for solving similar physics problems.
JoshHolloway
Hello all. I have a problem from my homework that I can't seem to figure out. It is a problem from a freshman introductory physics course. Here goes:
The position of a particle as a function of time given by: r =(5i^+4j^)t^2m , where t is in seconds. Find an expression for the particles velocity v as a function of time.
Where I wrote the ^ after the letters means its a unit vector.
Now isn't the way that one would find the velocity is to take the derivative of the expression? Or is that just for instantanious velocity? And if the way to find to velocity is to take the derivative, do I first distribute the t^2 then differentiate, ending up with: f'(t)=(10ti^+8tj^)m/s? Or do I use the product rule and end up with: f'(t)=(9t^2+10ti^+8tj^)m/s?
You take the derivatve. It doesn't matter if you distribute first, the coefficient of t^2 is a constant.
So the answer is v = f'(t) = (10ti^+8tj^)m/s ?
yup.
additional charaters to make the post 10 characters long
I don't understand what you mean by this.
