Solve Simple Velocity Problem: Understanding Integration and Momentum
  • Thread starter Thread starter teclo
    Velocity
To solve the velocity problem involving a 10 kg object with a force of F = 10 + 2t, integration is necessary because the force changes over time. The correct approach involves using dp = F(net) * dt, leading to the integration of the force function to find the total momentum change over the two seconds. The initial incorrect method assumed a constant force, which does not accurately reflect the varying force applied. By integrating, the area under the force-time curve provides the total momentum change, allowing for the correct calculation of final velocity. Understanding this integration process is crucial for accurately determining the effects of changing forces on momentum.
teclo
hi, I'm wondering if anyone could explain to me why one uses the following technique to solve this problem.
Let's say we've a 10 kg object. The force exerted on it is
F = 10 + 2t
The force acts on it for two (2) seconds. If it starts at rest, what is the final velocity?
I used this technique to solve the problem, after first making a mistake
dp = F(net) * dt
breaking that down to
dp = (10 + 2t) * dt
integration giving
10t + t^2 from 0 to 2
giving
24 kg * m/s
so
dp = 24 kg * m/s
m(v(2)-v(1)) = 24 kg * m/s
10 kg (v(2)-0) = 24 kg * m/s
v(2) = 2.4 m/s
this is the correct answer, however, initially i tried
m(v(2)-v(1)) = (10 + 2t) * dt
10 kg (v(2)-0) = 14N * 2s
resulting in a velocity of 2.8 m/s
why do i use integration before involving momentum is my question. thanks for anyone who might be able to help!
Even though i haven't taken calculus yet, according to your equation of the Force applied
F = 10 + 2t
The force applied during those 2 seconds is changing. thus you can't just use the quation F*t = change in momentum since you're saying the force of 14 N is applied for 2 seconds even though that wasn't true.
i hadn't though of it in that manner. i suppose i should have since force is related to time. the only reason i thought to use integration is because i had the equation p = (10 + 2t) *dt. the area of the graph would be in units of momentum.
thanks!
(still would appreciate explanation of usage of integration other than realizing area of function is in units of momentum)
Integrating a function is a method of finding the area beneath it. There's an elegant proof found in most calculus books that connects Rieman's sums (which is really just adding a bunch of infinately small shapes together to find area) to integration. Thus, since integration is much simpler than using Rieman's sums, integration is the preferred technique for finding area beneath a curve.
thanks for the help. i actually realized what was going on while on the way to the grocery store. p = F(net) dt -- if f is changing every t the area beneath the curve at that point would be the net force acting at t -- therefor by integrating from 0 to 2 I'm getting the total amount of force from that duration. from the net force i can determine velocity based on the change in momentum.
duh, I'm retarded
thanks again for the help.
The book claims the answer is that all the magnitudes are the same because "the gravitational force on the penguin is the same". I'm having trouble understanding this. I thought the buoyant force was equal to the weight of the fluid displaced. Weight depends on mass which depends on density. Therefore, due to the differing densities the buoyant force will be different in each case? Is this incorrect?
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 27 ·
