Simplex minimization problem reformation with modulus cost function
The discussion revolves around reformulating a minimization problem involving a modulus cost function, specifically |a-2b| + |-3a-b|, under certain constraints. The participants are exploring how to apply the simplex algorithm to this problem.
  • Participants discuss the possibility of introducing new variables to represent the absolute values and how to set up the constraints accordingly. There are questions about the validity of these reformulations and the implications of different constraints on the problem's feasibility and optimality.
The conversation is ongoing, with participants providing insights and questioning each other's reasoning. Some guidance has been offered regarding the formulation of the problem, but there is no explicit consensus on the best approach yet.
Participants are grappling with the implications of using inequalities versus equalities in their reformulations and how these affect the solution space. There is also a focus on understanding the relationship between the original variables and the newly introduced ones.
thomas49th
If I said minimize the cost function
|a-2b| + |-3a-b|
subject to
2a + b <= 6
a,b >= 0
We can all see it's 0,0 but if I want to apply the simplex algorithm to it, how do I reformulate the problem into something I can use
I thought about letting y = |a-2b|and z = |-3a-b|
then isn't y = a-2b, y = -a+2b
and z = -3a-b, z = 3a+b
then saying minimize y+z subject to
2a + b <= 6
y = a-2b
y = -a+2b
z = -3a-b
z = 3a+b
Is this allowed?
Thanks
Thomas
|a-2b| + |-3a-b|
subject to
2a + b <= 6
a,b >= 0
2a + b <= 6
y = a-2b
y = -a+2b
z = -3a-b
z = 3a+b
Is this allowed?
Thanks
Thomas
Not quite: you need inequalities y ≥ a-2b and y ≥ 2b - a, etc.
Obviously, if you impose both as equalities you must have y = a - 2b = 0. In this particular problem that would not give a wrong solution because the optimal solution is a = b = 0. However, if we changed the constraint to 2a + b >= 6, your suggestion would give a problem that might be far from optimal, or possibly even infeasible. (Actually, it would be infeasible, since it would require both 2b-a=0 and 3a + b = 0, with 2a + b >= 6 and a,b >= 0.)
Alternatively, you can write yp - yn = a - 2b, with yp, yn >= 0, and you want to minimize yp+yn. This formulation has more variables but fewer constraints. This can also be generalized to handle the problem of Maximizing the absolute values, but that problem needs additional binary variables plus some extra constraints---that is, it must be modeled as an MIP problem, rather than a pure LP: we need also that either yp = 0 or yn = 0. That happens automatically in the min problem, so can be ignored.
RGV
Hi,
I'm not quite sure why you can write this
yp - yn = a - 2b
What exactly are you trying to say here and where would yp + yn come from?
Thanks
Thomas
thomas49th said:
Hi,
yp - yn = a - 2b
Thanks
Thomas
Suppose, for example, that a - 2b = 5. What do you get when you solve the problem min yp+yn, subject to yp - yn = 5, yp, yn >= 0? If, instead, you have a - 2b = -5, what do you get when you solve the problem min yp + yn, subject to yp - yn = -5, yp, yn >= 0?
RGV
So basically yp - yn = 5 is a constraint
along with yp, yn >= 0.
my objective function is yp+yn
But how does a - 2b = 5 fit in here? What is the translate between y+ and y- and a and b?
Thanks
Thomas
Thanks
Thomas
Forget about a and b. Just answer my two questions: what would you get if you had (i) min yp + yn, st yp - yn = 5, yp,yn >=0; and if you had (ii) min yp + yn st yp -yn = -5, yp, yn >= 0?
RGV
The minimum is 5 in the first case and 0 in the second yes?
No, not 0 in the second case. For yp and yn >= 0, the only way to get yp + yn = 0 would be to have yp = yn = 0, and that would not satisfy the constraint yp - yn = -5.
RGV
sorry yeah equality as opposed to inequality, so it's 5 at y+ = 0, y- = 5.
So where are you trying to lead me to here?
Thanks
Thomas :P
Thanks
Thomas :P
Back to the beginning: you asked how to represent an absolute value minimization objective in linear terms. That is what I have been attempting to explain to you, but leaving you to do most of the work.
RGV
Thanks for the help,
But I'm not making the mental link
So far I know we can write |a-2b| as 2 inequalities
But I don't see how the equation
yp - yn = a - 2b
comes about, nor why we then go onto maximise yp+yn
Thanks
Thomas
yp - yn = a - 2b
Thanks
Thomas
Well, alright. You have already solved the problem one way, so I guess it is OK to supply the details of another way without violating the Forum rules.
The above is just the familiar splitting up of a number into positive and negative parts, then expressing the absolute value as the sum of the parts.
Look at min (p + n), subject to p-n = X, p,n >= 0. If X > 0, one feasible solution is (p,n) = (X,0); another feasible solution is (p,n) = (X+1,1), another is (p,n) = (X+2,2), ... and in general, a feasible solution is (p,n) = (X+t,t) for any t >= 0. However, among all these feasible solutions, the unique one that minimizes the sum p + n is (p,n) = (X,0). Next, suppose X < 0. One feasible solution is (p,n) = (0,-X) (noting that -X = |X| > 0); another is (p,n) = (1,-X+1), another is (p,n) = (2,-X+2), ... . Among these, the unique one that minimizes p+n is (p,n) = (0,-X) = (0,|X|), giving p+n = |X|. So, for the problem min (p+n), st p-n = X, p,n >= 0, we have
(p+n)min = |X|.
Of course, using min z, s.t. z >= X and z >= -X is another way. One way has fewer variables and more constraints, the other has more variables and fewer constraints. Each method has advantages in certain contexts.
RGV
All good upto here
I feel like a complete incompetent.
p-n=X. So we set p = 0. n = -X. Ok the first bit makes sense but I don't understand how I can "note" -X = |X| > 0. You're saying that -X is the same as |X| (when the modulus of X is greater than 0 (aka X is not zero)).
Maybe you already did, but can you show me exactly how you obtained -X = |X| > 0 and (p,n) = (0,-X) = (0,|X|)
Many many thanks
Thomas
thomas49th said:
All good upto here
Many many thanks
Thomas
No. When X > 0 we set p = X and n = 0. When X < 0 (that is, when X = -|X|) we set p = 0 and n = |X| = -X > 0.
OK, one very last time! Look: 5 = 5 - 0 = 6 - 1 = 7 - 2 = 8 - 3 = ... . There are lots of ways to write 5 as p-n with p,n >= 0, but the way that minimizes p+n is the first one: p = 5 and n = 0, giving p+n = 5 = |5|. Next, consider -5. We have -5 = 0 - 5 = 1 - 6 = 2 - 7 = 3 - 8 = ... . There are lots of ways to write -5 as p - n with p,n >= 0, but the one that minimizes p+n is the first one: p = 0 and n = 5. This gives p+n = 5 = |-5|.
Now I'm out of here.
RGV
