Simplifying (a - b)/(a⁻¹ - b⁻¹)
4 replies · 3K views · last reply
velox_xox
First of all, thank you, everyone, for all your help with my math conundrums! I've really appreciated the patience and helpful hints - because I do want to learn it myself, so this method is just enough for me to cut the math problems down to size. I'm thankful. And, I have noticed my scores improved because I'm recognizing my trouble areas more often. So, to anyone out there shy to ask for help, I do suggest this forum. It's been very useful!
Simplify. (a - b)/(a-1 - b-1)
Answer: -ab
This lesson is teaching that you can either simplify the numerator and denominator separately and divide; or multiply the whole thing by the LCD and then simpify.
(a - b)/(a-1 - b-1)
Switched to a different format.
(a-b)/1 ÷ (a-1 - b-1)/1
Get rid of negative exponents.
(a-b)/1 ÷ 1/(a - b)
Invert the second fraction & switch to multiplication.
(a-b)/1 X (a-b)/1
Perform multiplication.
a2 - 2ab - b2
(a-b)/1 ÷ 1/(a - b)
Hi velox! This step is wrong! It might be easier to see the two cases you are confusing in fraction form: [itex]a^{-1}-b^{-1}= \displaystyle \frac{1}{a}-\frac{1}{b}[/itex] and [itex](a-b)^{-1} = \displaystyle \frac{1}{a-b}[/itex]
Whatever is being raised to the negative one gets flipped. All nearby operators stay the same. So in the first case that I showed above, the a and the b, individually, are raised to the negative one. So a and b, individually, get "flipped" and the minus sign stays where it is. In the second case the whole expression is raised to the negative one; so the whole expression gets flipped.
I hope that helps! Try getting the correct answer now!
Hi scurty, it's nice to have your help again!
That's right, the denominators need to be the same in subtraction with fractions, so I see that the separate 1/a - 1/b and 1/a-b aren't the same. I guess I need to watch out for that.
So, then...
(a - b)/(1/a - 1/b)
Use the LCD of 'ab' to create a common denominator.
{(a - b)/(b - a)/(ab)}
Turn the complex fraction into two simple ones.
(a - b)/1 ÷ (b - a)/(ab)
Invert the second fraction and change the sign to multiplication (and also change the denominator of the second fraction to the proper form).
(a - b)/1 X (ab)/(-a + b)
Factor out the '-1' from the denominator of the second fraction.
(a - b)/1 X (ab)/-1(a - b)
Simplify.
(ab)/-1
Divide.
-ab
Is this correct??
Well, that was fast. Thank you so much scurty! Have a good weekend!
