Simplifying Trig Ratio Identities: Does This Answer Make Sense?
  • Thread starter Thread starter supernova1203
4 replies · 2K views
supernova1203
Trig ratios identities problems, in this case i am not asked to prove anything, just asked to simplify(Solve)
im left with
(1/costheta)(1/costheta)
At this point do we cross multiply?
we would end up with
costheta/costheta = 1
does this make sense? I encountered a similar problem earlier and it was somewhat like this where the solution was 1.
are you saying that from
x = (1/cos(theta))(1/cos(theta))
you arrive at cos(theta)/cos(theta) = x = 1?
that would not be correct...
however the statement
cos(theta)/cos(theta) = 1 would certainly be correct
No, it isn't correct.
You do not cross multiply unless they are equal to each other. In this case, you should multiply normally. You started with (1/cosθ)(1/cosθ), correct?
So in that case (1/cosθ)(1/cosθ) = 1/cos2θ = sec2θ
Yes it doesn't add up
For example 1/cos(theta) x 1/cos (theta) is the same as saying 1/cos^2(theta) does this equal 1?
Find a trig identity that would explain it in different terms I think is your best bet.
Ok that was redundant whs^. :smile:
[tex]\frac{1}{a}\frac{1}{a}= \frac{1}{a^2}[/tex]
not 1.
If you were dividing, it would be
[tex]\frac{\frac{1}{a}}{\frac{1}{a}}= 1[/tex]
