Single Slit Interference Pattern: Increased Distance
1 reply · 3K views · last reply
belbin09
A laser emitting light with a wavelength of 560 nm is directed at a single slit, producing an interference pattern on a screen that is 3.0 m away. The central maximum is 5.0 cm wide.
What would the effect on this pattern be, if the screen was moved further away?
Δy = λL/w
ATTEMPT AT SOLUTION
The effect on the pattern when the screen is moved further away is the bright fringes would become wider, the light intensity of the bright fringes would decrease, and the bright fringes will appear closer together.
REASONING
I answered this question based on how light works against a screen in general. The part I get stuck on is how the dark fringes would appear. I state that the bright fringes "appear" closer together because as the distance between the slit and the screen increases the bright fringes would become wider, spreading the light outwards making the dark fringes harder to distinguish. Would the dark fringes actually get smaller or is it just a perception?
  • Homework problem text: a laser of wavelength 560 nm passes a single slit onto a screen 3.0 m away, central maximum 5.0 cm wide; parts a (find slit width and fringe spacing) and b (effects of smaller slit and larger screen distance).
What expressions do you know about where the bright and dark fringes appear? What quantities are relevant? Start from there.
