Singular solutions Separable Eq. and IVP
  • Context: Graduate
  • Thread starter Thread starter ximath
    Ivp Separable
The discussion centers on the relationship between singular solutions and initial value problems (IVPs) in the context of separable differential equations. The IVP is presented in the form y' = f(x,y) with a specific condition y(x0) = y0. The participant highlights the confusion arising from the general solution y = (x-c)^2, which appears to yield a valid particular solution y = 0 when substituting x = 0, despite the assumption that y is not equal to 0 during separation. This indicates that singular solutions cannot be derived from general solutions, yet they coexist within the framework of the differential equation.
  • Understanding of initial value problems (IVPs)
  • Knowledge of separable differential equations
  • Familiarity with the concept of singular solutions
  • Basic calculus, particularly integration techniques
  • Study the implications of singular solutions in differential equations
  • Explore the method of separation of variables in depth
  • Investigate the continuity requirements for derivatives in differential equations
  • Learn about the existence and uniqueness theorems for solutions to IVPs
Mathematics students, educators, and researchers focusing on differential equations, particularly those interested in the nuances of singular solutions and initial value problems.
ximath
Hi,
I am a little bit confused about singular solutions and their relationship with IVP's and decided to ask you.
As far as I understood, the IVP's could be in a form:
y' = f(x,y)
y(x0) = y0
To obtain a general solution, we could use separable eq. method. I have learned that sometimes when we separate the variables, we assume a particular condition to be valid. (that might have an asymptotic behaviour. )
Also, as far as I know, a singular solution can not be obtained from a general solution.
My impression was that the general solution shouldn't have worked for y = y0 if we derived it assuming y is not equal to y0. However, that example confuses me;
y' = 2 (y^1/2)
y(0) = 0
By the sep. eq. method and integrating both sides;
(dy / 2(y^1/2)) = dx
I have found that y = (x-c)^2. However, while separating, we actually assume that y is not equal to 0.
What's confusing is, at this general solution, when I plug y = 0 and x = 0; I get a particular solution; which is y = x^2 and that perfectly works well! It does not make sense to get a particular solution which suggests y= 0 when x = 0 using a general solution that is not defined for y = 0. (Because I had assumed y is not equal to 0 while I was separating the variables. )
It is sufficient to solve for y with y not 0, then extend the solution to y= 0 since, in order that the derivative exist, y must be continuous.
But did you notice that y(x)= 0 for all x is also a solution? In fact, if you set y(x)= (x- a)2 for x< a< 0, y(x)= 0 for a< x< b (where b> 0), y(x)= (x-b)2 for 0< b< x is also a solution to the differential equation satisfying y(0)= 0.
  • · Replies 16 ·
  • · Replies 36 ·
