Understanding the Significance of Imaginary Frequencies in Chemical Reactions
The discussion focuses on the significance of imaginary frequencies in the transition state of chemical reactions, specifically addressing the implications of a negative eigenvalue in the Hessian matrix. An imaginary frequency, such as 1000i, indicates that the corresponding eigenvalue is negative, leading to a downward-sloping energy profile described by the equation E = -1/2 q² |w²|. The participants clarify that while positive frequencies can provide insights into bond energies, negative frequencies do not directly correlate with dissociation energies but rather reflect local curvature at stationary points in potential energy surfaces.
  • Understanding of Hessian matrices in quantum chemistry
  • Familiarity with eigenvalues and eigenvectors
  • Knowledge of potential energy surfaces
  • Basic principles of vibrational spectroscopy
  • Research the role of Hessian matrices in transition state theory
  • Study the implications of imaginary frequencies in vibrational analysis
  • Explore potential energy surface curvature and its relation to reaction dynamics
  • Learn about the interpretation of eigenvalues in quantum mechanical systems
Chemists, particularly those specializing in quantum chemistry, computational chemists, and researchers interested in reaction mechanisms and vibrational analysis.
greisen
Hi,
In the transition state of a chemical reaction defined as one imaginary eigenvalue of the hessian matrix - the size of my frequency is 1000i what can one say about the size of the imaginary frequency - is it related to energy in some way ? I have not been able to find any documents commenting on the size of the imaginary eigenvalue.
Any help or advise appreciated. Thanks in advance
The eigenvalue is negative- the frequency is the sqrt of the eigenvalue, which is imaginary.
The potential energy along the eigenvector direction is 1/2 q^2 w^2, which in your case is an 'upside-down' parabola.
thanks - I am a little puzzled how to interpret to values when they are imaginary - if you have a C-H bond with frequency of 1300 cm^-1 you can say something about the energy of the bond or mode but when you have -1300 cm^-1 what to say about it than? I mean the bond/stretch should have the same energy but in one case it is denoted having a negative frequency instead of a positive.
eigenvalue = w^2
If the eigenvalue is negative- then w is imaginary.
Energy = 1/2 q^2 w^2
If the eigenvalue is negative then the energy goes as E= -1/2 q^2 |w^2|, i.e. the energy slopes downwards (along a parabola) if you move forward or backward along q.
You can't tell anything about the dissociation energy from the frequencies- they can only tell you about the local curvature at the stationary point.
  • · Replies 78 ·
  • · Replies 0 ·
