Solve 1D Motion Questions: Determine Velocity, Max Height, Time Req.
oreosama
a rock is thrown nearly vertical upward from the edge of a tall building of height H. it just misses the edge of the building on the way down and strikes the ground T seconds after being thrown. given H, T
determine the initial velocity of the rock
the max height it reaches above its starting point
the time to reach its max height
v= v_0 + at
x = x_0 + v_0*t + 1/2*a*t^2
v^2 = v_0^2 + 2a(x - x_0)
x_0 = H
x = 0
v_0 = ?
v = ?
a = g
t = T
with these as inputs I don't see how I can manipulate algebra to get the things I want. this is a recurring theme with the rest of my homework it seems:
a flowerpot falls off a windowsill and falls past a window below. a person inside the building notices that it takes T seconds to go from the top to the bottom of the window. the window is h meters high. given h, T
determine how far above the window is the windowsill.
v= v_0 + at
v^2 = v_0^2 + 2a(x - x_0)x_0 = 0
x = q + h (figuring out q is the goal)
v_0 = 0
v = v
a = g
t = Tone again i feel like when i mess with the algebra i end up going in circles where I can't get everything solved within means of the terms given... hurts my head. i think I am doing something fundamentally wrong, let me know.
1. x_0 = H
x = 0
v_0 = ?
v = ?
a = g
t = T
x=H
x_0=0
2. x=u2/2a
h=ut+0.5at2
With [itex]v_0[/itex], the object can reach the maximum height [itex]h[/itex] (relative to the top of the building). That gives you an equation relating [itex]v_0[/itex] and [itex]h[/itex]. It takes [itex]T_u[/itex] to lose the initial speed [itex]v_0[/itex] going upward to the maximum height. That gives you an equation relating [itex]v_0[/itex] and [itex]T_u[/itex]. It takes [itex]T_d[/itex] to fall from [itex]H + h[/itex] to the ground. That gives you an equation relating [itex]H[/itex], [itex]T_d[/itex] and [itex]h[/itex]. And [itex]T_u + T_d = T[/itex]. So you have four equations and four unknowns [itex]v_0[/itex], [itex]h[/itex], [itex]T_u[/itex] and [itex]T_d[/itex], which you can solve.
