Solve Basic Spring Problem: Minimum Distance Between Connected Blocks
  • Thread starter Thread starter fireemblem13
    Spring
The discussion revolves around a physics problem involving a moving block and two connected blocks at rest via a spring. The main question is to determine the minimum distance between the two blocks to prevent one from hitting the other when impacted by the moving block. Participants clarify that the spring's role is to prevent block B from colliding with block C. The problem requires understanding the dynamics of the spring and the forces involved. Overall, the focus is on analyzing the motion and interactions of the blocks to find the required minimum distance.
fireemblem13
Tell me if this question makes any sense.
One block moving with velocity v_0 hits a system of two blocks at rest connected by an undeformed spring with spring constant k. Find the minimum distance between the blocks attached to the spring. All masses are of equal mass.
I'm not quite sure what to do with this. I don't see what's limiting the distance between the blocks.
Welcome to PF!
Hi fireemblem13! Welcome to PF! :wink:
Block A is moving. There is a spring between blocks B and C. The spring will stop B from hitting C. :smile:
So, it's asking the minimum distance B and C can be so that B does not hit C when A hits B?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
