Solve Convolution Problem: Find y(t) Given h(t) and f(t)
  • Thread starter GreenPrint
    Convolution
GreenPrint
The unit impulse response of an LTIC system is h(t) = [itex]e^{-t}u(t)[/itex]. Find the system's (zero-state) response y(t) if the input f(t) is [itex]e^{-2t}u(t-3)[/itex].
y(t) = f(t) * h(t) = [itex]∫^{∞}_{-∞}f(t)h(t-\tau)d\tau[/itex]
[itex]f_{1}(t) * f_{2}(t ) = c(t)[/itex]
[itex]f_{1}(t) * f_{2}(t - T) = c(t - T)[/itex]
I'm not sure how to apply the shifting property because here in f(t) I have the unit step function only which is shifted and not the exponential. Is it possible to apply the shifting property above for this problem? I don't see how I can apply it for the reason mentioned above.
Thanks for any help.
Hint: Use ##t = (t-3)+3## in the exponential in f(t).
Thanks. I was able to do it. I'm however now stuck on a some what more challenging problem.
[itex]-\delta(t) * e^{t}u(-t) \stackrel{Δ}{=} ∫^{\tau = ∞}_{\tau = -∞}e^{t}u(-\tau)(-\delta(t-\tau))d\tau[/itex]
I know that
[itex]f(t) * \delta(t-T) = f(t - T)[/itex]
But I'm unsure how to apply this here. I guess in my case [itex]T = 0[/itex] but how do I tell with the negative sign of the dirac delta function? Is my solution
[itex]-e^{t}u(-t)[/itex]?
Thanks for help.
You can pull the negative sign right out of the integral, right? So you should be able to see that
$$[-\delta(t)]*e^t u(-t) = -[\delta(t)*e^t u(-t)]$$
